<!– Class –> This class serializes an object.
*System.Object **ThinkGeo.MapSuite.PortableCore.GeoSerializer
GeoSerializer | Creates an instance of GeoSerializer. | ||
GeoSerializer | GeoSerializationFormatter |
Deserialize | String, GeoFileAccess | Recreates an object from a file. | |
Deserialize | Stream | Recreates an object from a stream. | |
Deserialize | String | Recreates an object from a string. | |
Deserialize | Uri | Recreates an object from an Url. | |
Serialize | Object, String | Serialize an object and save the serialized data to a file. | |
Serialize | Object, Stream | Serialize an object and save the serialized data to a stream. | |
Serialize | Object | Serialize an object and save the serialized data to a string. | |
Formatter | GeoSerializationFormatter | Gets or sets the Formatter. The Formatter determines what kind of serialized data will be created. |
| formatter | GeoSerializationFormatter<!– ThinkGeo.MapSuite.PortableCore.GeoSerializationFormatter –> |
| Object<!– System.Object –> | The recreated object. |
| sourcePathFileName | String<!– System.String –> | The file path to deserialize from. |
| fileAccess | GeoFileAccess<!– ThinkGeo.MapSuite.PortableCore.GeoFileAccess –> | The FileAccess |
<!– ThinkGeo.MapSuite.PortableCore.GeoSerializer –> Go Back
| sourceStream | Stream<!– System.IO.Stream –> | The Stream to deserialize from. |
| sourceString | String<!– System.String –> | The string to deserialize from. |
| sourceUri | Uri<!– System.Uri –> | The Url to deserialize from. |
| objectToSerialize | Object<!– System.Object –> | The object to be serialized. |
| targetPathFileName | String<!– System.String –> | The path to save the serialized data to. |
| targetStream | Stream<!– System.IO.Stream –> | The stream to save the serialized data into. |
| String<!– System.String –> | The string that contains the serialized data. |
