<!– Class –> This class formats a GeoObjectModel into serialized data.
*System.Object ThinkGeo.MapSuite.PortableCore.GeoSerializationFormatter *ThinkGeo.MapSuite.PortableCore.XmlGeoSerializationFormatter
GeoSerializationFormatter | Creates an instance of GeoSerializationFormatter. |
Load | Stream | Load a stream into a GeoObjectModel. | |
Save | GeoObjectModel, Stream | Save serialized data into a stream. | |
LoadCore | Stream | Load a stream into a GeoObjectModel. | |
MemberwiseClone | Object | ||
SaveCore | GeoObjectModel, Stream | Format a GeoObjectModel into serialized data, and save the data into a stream. |
Encoding | Encoding | set or get the readEncoding. |
| GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The GeoObjectModel recreated from the stream. |
| stream | Stream<!– System.IO.Stream –> | The Stream to load from. |
<!– ThinkGeo.MapSuite.PortableCore.GeoSerializationFormatter –> Go Back
| model | GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The GeoObjectModel to create serialized data for. |
| stream | Stream<!– System.IO.Stream –> | The Stream to save serialized data into. |
| Encoding<!– System.Text.Encoding –> |
