<!– Enumeration –> This enumeration defines the various kinds of hatch patterns that can be used to fill areas using the GeoHatchBrush.
| Name | Summary |
| Horizontal | A Horizontal pattern fill. |
| Vertical | A Vertical pattern fill. |
| ForwardDiagonal | A Forward Diagonal pattern fill. |
| BackwardDiagonal | A Backward Diagonal pattern fill. |
| LargeGrid | A Large Grid pattern fill. |
| DiagonalCross | A Diagonal Cross pattern fill. |
| Percent05 | A 05 Percent pattern fill. |
| Percent10 | A 10 Percent pattern fill. |
| Percent20 | A 20 Percent pattern fill. |
| Percent25 | A 25 Percent pattern fill. |
| Percent30 | A 30 Percent pattern fill. |
| Percent40 | A 40 Percent pattern fill. |
| Percent50 | A 50 Percent pattern fill. |
| Percent60 | A 60 Percent pattern fill. |
| Percent70 | A 70 Percent pattern fill. |
| Percent75 | A 75 Percent pattern fill. |
| Percent80 | A 80 Percent pattern fill. |
| Percent90 | A 90 Percent pattern fill. |
| LightDownwardDiagonal | A Light Downward Diagonal pattern fill. |
| LightUpwardDiagonal | A Light Upward Diagonal pattern fill. |
| DarkDownwardDiagonal | A Dark Downward Diagonal pattern fill. |
| DarkUpwardDiagonal | A Dark Upward Diagonal pattern fill. |
| WideDownwardDiagonal | A Wide Downward Diagonal pattern fill. |
| WideUpwardDiagonal | A Wide Upward Diagonal pattern fill. |
| LightVertical | A Light Vertical pattern fill. |
| LightHorizontal | A Light Horizontal pattern fill. |
| NarrowVertical | A Narrow Vertical pattern fill. |
| NarrowHorizontal | A Narrow Horizontal pattern fill. |
| DarkVertical | A Dark Vertical pattern fill. |
| DarkHorizontal | A Dark Horizontal pattern fill. |
| DashedDownwardDiagonal | A Dashed Downward Diagonal pattern fill. |
| DashedUpwardDiagonal | A Dashed Upward Diagonal pattern fill. |
| DashedHorizontal | A Dashed Horizontal pattern fill. |
| DashedVertical | A Dashed Vertical pattern fill. |
| SmallConfetti | A Small Confetti pattern fill. |
| LargeConfetti | A Large Confetti pattern fill. |
| ZigZag | A Zig Zag pattern fill. |
| Wave | A Wave pattern fill. |
| DiagonalBrick | A Diagonal Brick pattern fill. |
| HorizontalBrick | A Horizontal Brick pattern fill. |
| Weave | A Weave pattern fill. |
| Plaid | A Plaid pattern fill. |
| Divot | A Divot pattern fill. |
| DottedGrid | A Dotted Grid pattern fill. |
| DottedDiamond | A Dotted Diamond pattern fill. |
| Shingle | A Shingle pattern fill. |
| Trellis | A Trellis pattern fill. |
| Sphere | A Sphere pattern fill. |
| SmallGrid | A Small Grid pattern fill. |
| SmallCheckerBoard | A Small Checker Board pattern fill. |
| LargeCheckerBoard | A Large Checker Board pattern fill. |
| OutlinedDiamond | A Outlined Diamond pattern fill. |
| SolidDiamond | A Solid Diamond pattern fill. |
| Min | A Min pattern fill. |
| Max | A Max pattern fill. |
| Cross | A Cross pattern fill. |
