<!– Class –> This class represents general image types to be drawn on the map, such as .BMP, .JPG, .PNG, etc.
This type of layer is used to draw standard image types on the map. These include .BMP, .JPG, .PNG, .TIFF, and all other image types that are supported by the .NET Framework to be loaded as a Bitmap.
Each of these images will need a world file associated with it. The world file contains the geospatial information pertaining to the image. Using the world file, we know its spatial position and other required information to draw it on the map relative to other images or spatial features. World files are small text files with an extension that matches the original image's extension, but with the middle character of the extension changed to a “w”. If you have images that you want to use but do not have their world files, please contact the source of the image so that they can provide one for you. world files are fairly common in the GIS community.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.RasterLayer ThinkGeo.MapSuite.PortableCore.GdiPlusRasterLayer
![]() | This is a constructor for the class. | ||
![]() | String | This is a constructor for the class. | |
![]() | String, String | This is a constructor for the class. | |
![]() | String, RectangleShape | This is a constructor for the class. |
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | Object | ||
![]() | RasterLayer | This method returns the horizontal resolution of the image. | |
![]() | RasterLayer | This method returns the projection parameters of the current layer. | |
![]() | Object | ||
![]() | RasterLayer | This method returns the vertical resolution of the image. | |
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | Layer | ||
![]() | RectangleShape | Layer | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | TimeSpan | Layer | |
![]() | RectangleShape, TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer(overriden) | ||
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method will draw the image from the GeoImage source based on the parameters provided. |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | String | Layer | |
![]() | Single | RasterLayer | This property gets and sets the amount of blue to apply to the image. |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | Single | RasterLayer | This property gets and sets the amount of green to apply to the image. |
![]() | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GdiPlusRasterLayer, we override this API and mark it as true. |
![]() | Boolean | RasterLayer | This property returns true if the RasterLayer contains projection parameters and false if it does not contain any projection parameters. |
![]() | RasterSource | RasterLayer | This property gets and sets the ImageSource used by the RasterLayer. |
![]() | Boolean | RasterLayer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | RasterLayer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Collection<GeoColor> | RasterLayer | Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors. |
![]() | Double | RasterLayer | This property gets and sets the lower threshold in the scale at which to display the image. |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | String | This property gets and sets the path and filename of the image file you want to use. | |
![]() | Single | RasterLayer | This property gets and sets the amount of red to apply to the image. |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | Double | RasterLayer | This property gets and sets the upper threshold in the scale at which to display the image. |
![]() | StreamLoadingEventArgs | This event allows you to pass in your own stream to represent the image. |
This is the default constructor. If you use this constructor, then you need to set the PathFileName property manually before using the layer.
Name | Type | Description |
This constructor allows you to provide the path and filename information for the GDI+ image file.
pathFilename | String<!– System.String –> | This parameter is the path and filename of the GDI+ image file you want to use. If you want to load a Tiff(.tif or .tiff) files, please use the GeoTiffRasterLayer instead for better performance. |
This constructor allows you to provide the path and filename information for both the GDI+ image file and its world file.
worldfilePathFilename | String<!– System.String –> | This parameter is the world file path and filename for the GDI+ image you want to use. |
This constructor allows you to provide the path and filename for the GDI+ image file and the image extent to use.
imageExtent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This parameter is the image extent of GDI+ image file you want to use. |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
Void<!– System.Void –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
Single<!– System.Single –> | This method returns the horizontal resolution of the image. |
<!– ThinkGeo.MapSuite.PortableCore.RasterLayer –> Go Back
String<!– System.String –> | This method returns the projection parameters of the current layer. |
Type<!– System.Type –> |
Single<!– System.Single –> | This method returns the vertical resolution of the image. |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
The DrawCore method will be called when the layer is being drawn. It will determine if the image is within the extent and the threshold defined. If these parameters are met, it will query the RasterSource for an image and then apply the other various properties (such as transparency, etc.) on the image. Lastly, it will draw the image on the GeoImage or native image passed into the method.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the GeoCanvas used to Draw the RasterLayer. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter is not used for ImageLayers. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
Return Type |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
Return Type |
Return Type |
Return Type |
Return Type |
The set for this property is protected and only intended to be used by developers who are creating their own ImageSources. This is the main property to set for developers who are creating their own RasterLayer derivatives.
Return Type |
RasterSource<!– ThinkGeo.MapSuite.PortableCore.RasterSource –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.GeoColor} –> |
Below the lower threshold in scale, the image will not be displayed. This, in conjunction with the UpperThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type |
Double<!– System.Double –> |
Return Type |
This should be a complete path and filename for the image file.
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.GdiPlusRasterLayer –> Go Back
Return Type |
Return Type |
Return Type |
Above the upper threshold in scale, the image will not be displayed. This, in conjunction with the LowerThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
If you wish, you can pass in your own stream to represent the image. The stream can come from a variety of places, including isolated storage, a compressed file, or an encrypted stream. When the image is finished with the stream it will dispose of it, so be sure to keep this in mind when passing the stream in. If you do not pass in an alternate stream, the class will attempt to load the file from the file system using the PathFileName property.
Event Arguments |
StreamLoadingEventArgs<!– ThinkGeo.MapSuite.PortableCore.StreamLoadingEventArgs –> |
