<!– Structure –> This structure represents the drawing of a rectangle in screen coordinates.
*System.ValueType **ThinkGeo.MapSuite.PortableCore.DrawingRectangleF
![]() | Single, Single, Single, Single | This method represents the constructor that should be used to create the structure. |
![]() | Object | Object(overriden) | This method is an override of the Equals functionality. |
![]() | Object(overriden) | This method is an override of the GetHashCode functionality. | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Single | ||
![]() | Single | This parameter represents the center horizontal value of the rectangle. | |
![]() | Single | This parameter represents the center vertical value of the rectangle. | |
![]() | Single | This parameter returns the height of the rectangle. | |
![]() | Single | ||
![]() | Single | ||
![]() | Single | ||
![]() | Single | This parameter returns the width of the rectangle. |
Name | Type | Description |
centerX | Single<!– System.Single –> | This parameter represents the center horizontal value of the rectangle. |
centerY | Single<!– System.Single –> | This parameter represents the center vertical value of the rectangle. |
width | Single<!– System.Single –> | This parameter represents the width of the rectangle. |
height | Single<!– System.Single –> | This parameter represents the height of the rectangle. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
