<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.CogoCall *ThinkGeo.MapSuite.PortableCore.DirectionDistanceCogoCall
![]() | Double, Double |
![]() | Object | Object | |
![]() | PointShape, PointShape | CogoCall | |
![]() | CogoDirectionType, AngleUnit | CogoCall | This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method. |
![]() | Object | ||
![]() | Object | ||
![]() | String, CogoDirectionType, AngleUnit | CogoCall | This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method. |
![]() | Object |
![]() | Object | ||
![]() | PointShape, PointShape | CogoCall(overriden) | |
![]() | CogoDirectionType, AngleUnit | CogoCall(overriden) | |
![]() | String, CogoDirectionType, AngleUnit | CogoCall(overriden) | |
![]() | Object |
![]() | Double | ||
![]() | Boolean | CogoCall | This porperty denotes if this call is the point of begining. This is the point from which we will begin the polygon |
![]() | Double |
Name | Type | Description |
northAzimuthDirectionInDegree | Double<!– System.Double –> | |
distanceInFeet | Double<!– System.Double –> |
Return Type | Description |
LineShape<!– ThinkGeo.MapSuite.PortableCore.LineShape –> |
startPoint | PointShape<!– ThinkGeo.MapSuite.PortableCore.PointShape –> | |
backsightPoint | PointShape<!– ThinkGeo.MapSuite.PortableCore.PointShape –> |
<!– ThinkGeo.MapSuite.PortableCore.CogoCall –> Go Back
String<!– System.String –> |
returningDirectionType | CogoDirectionType<!– ThinkGeo.MapSuite.PortableCore.CogoDirectionType –> | |
returningAngleUnit | AngleUnit<!– ThinkGeo.MapSuite.PortableCore.AngleUnit –> |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Void<!– System.Void –> |
traverseString | String<!– System.String –> | |
directionType | CogoDirectionType<!– ThinkGeo.MapSuite.PortableCore.CogoDirectionType –> | |
angleUnit | AngleUnit<!– ThinkGeo.MapSuite.PortableCore.AngleUnit –> |
<!– ThinkGeo.MapSuite.PortableCore.CogoCall(overriden) –> Go Back
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.DirectionDistanceCogoCall –> Go Back
Return Type |
Return Type |
