<!– Class –> This static class provides a conversion method to go to and from different units.
*System.Object **ThinkGeo.MapSuite.PortableCore.Conversion
![]() ![]() | Double, AngleUnit, AngleUnit | ||
![]() ![]() | Double, DistanceUnit, DistanceUnit | This method converts from one unit of measure to another. | |
![]() ![]() | Double, AreaUnit, AreaUnit | This method converts from one unit of measure to another. | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
<!– static –>
Return Type | Description |
Double<!– System.Double –> |
Name | Type | Description |
angle | Double<!– System.Double –> | |
fromUnit | AngleUnit<!– ThinkGeo.MapSuite.PortableCore.AngleUnit –> | |
toUnit | AngleUnit<!– ThinkGeo.MapSuite.PortableCore.AngleUnit –> |
<!– ThinkGeo.MapSuite.PortableCore.Conversion –> Go Back
<!– static –> This method converts from one unit of measure to another.
This overload handles length units.
Double<!– System.Double –> | The return length size, represented in the unit specified in the toUnit parameter. |
amount | Double<!– System.Double –> | The total length size, represented in the unit specified in the fromUnit parameter. |
fromUnit | DistanceUnit<!– ThinkGeo.MapSuite.PortableCore.DistanceUnit –> | The unit of measure for the length in the Amount parameter. |
toUnit | DistanceUnit<!– ThinkGeo.MapSuite.PortableCore.DistanceUnit –> | The unit of measure for the result. |
This overload handles area units.
Double<!– System.Double –> | The return area size, represented in the unit specified in the toUnit parameter. |
amount | Double<!– System.Double –> | The total area size, represented in the unit specified in the fromUnit parameter. |
fromUnit | AreaUnit<!– ThinkGeo.MapSuite.PortableCore.AreaUnit –> | The unit of measure for the area in the Amount parameter. |
toUnit | AreaUnit<!– ThinkGeo.MapSuite.PortableCore.AreaUnit –> | The unit of measure for the result. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
