thinkgeo.mapsuite.portablecore.compositestyle
ThinkGeo.MapSuite.PortableCore.CompositeStyle
<!– Class –>
Public MethodCompositeStyle
Public MethodCompositeStyle Style
Public MethodCompositeStyle IEnumerable<Style>
Public MethodCloneDeep Style Create a copy of style using the deep clone process.
Public MethodDraw IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the features on the canvas you provided.
Public MethodDraw IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the shapes on the canvas you provided.
Public MethodDrawSample GeoCanvas, DrawingRectangleF Style This method draws a sample feature on the canvas you provided.
Public MethodDrawSample GeoCanvas Style
Public MethodGetRequiredColumnNames Style This method returns the column data for each feature that is required for the style to properly draw.
Public MethodGetType Object
Public MethodToString Object
Protected MethodCloneDeepCore Style Create a copy of style using the deep clone process. The default implementation method uses serialization.
Protected MethodDrawCore IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style(overriden)
Protected MethodDrawSampleCore GeoCanvas, DrawingRectangleF Style(overriden)
Protected MethodGetRequiredColumnNamesCore Style(overriden)
Public PropertyFilters Collection<String> Style
Public PropertyIsActive Boolean Style This property gets and sets the active status of the style.
Public PropertyName String Style This property gets and set the name of the style.
Public PropertyRequiredColumnNames Collection<String> Style This property gets the collection of fields that are required for the style.
Public PropertyStyles ObservableCollection<Style>
Protected PropertyFiltersCore Collection<String> Style(overriden)
CompositeStyle()
Name Type Description
Go Back
CompositeStyle(Style)
style Style<!– ThinkGeo.MapSuite.PortableCore.Style –>
Go Back
CompositeStyle(IEnumerable<Style>)
styles IEnumerable<Style><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Style} –>
Go Back
CloneDeep()
Return Type Description
Style<!– ThinkGeo.MapSuite.PortableCore.Style –> A cloned style.
<!– ThinkGeo.MapSuite.PortableCore.Style –> Go Back
Draw(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
Void<!– System.Void –>
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> This parameter represents the features you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> This parameter represents the canvas you want to draw the features on.
labelsInThisLayer Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> The labels will be drawn in the current layer only.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> The labels will be drawn in all layers.
Draw(IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BaseShape} –> This parameter represents the shapes you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> This parameter represents the canvas you want to draw the shapes on.
DrawSample(GeoCanvas, DrawingRectangleF)
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
drawingExtent DrawingRectangleF<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –>
DrawSample(GeoCanvas)
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetRequiredColumnNames()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of column names that the style needs.
Type<!– System.Type –>
String<!– System.String –>
CloneDeepCore()
DrawCore(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
<!– ThinkGeo.MapSuite.PortableCore.Style(overriden) –> Go Back
DrawSampleCore(GeoCanvas, DrawingRectangleF)
GetRequiredColumnNamesCore()
Filters
Return Type
IsActive
Return Type
Return Type
RequiredColumnNames
Return Type
Styles
Return Type
ObservableCollection<Style><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.PortableCore.Style} –>
<!– ThinkGeo.MapSuite.PortableCore.CompositeStyle –> Go Back
FiltersCore
Return Type
thinkgeo.mapsuite.portablecore.compositestyle.1440040132.txt.gz · Last modified: 2015/09/21 08:05 (external edit)
