<!– Class –> This class represents the parameters passed in through the CommittingTransaction event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.PortableCore.CommittingTransactionEventArgs
CommittingTransactionEventArgs | TransactionBuffer | This is the default constructor for the event. | |
CommittingTransactionEventArgs | This is the constructor of the event arguments. |
Cancel | Boolean | This property allows you to cancel the transaction. | |
TransactionBuffer | TransactionBuffer | This property returns the transaction buffer that needs to be committed. |
This is the constructor that allows you to pass in a transaction buffer.
| transactionBuffer | TransactionBuffer<!– ThinkGeo.MapSuite.PortableCore.TransactionBuffer –> | This parameter represents the transaction buffer that needs to be committed. |
This is the default constructor for the event arguments.
<!– ThinkGeo.MapSuite.PortableCore.CommittingTransactionEventArgs –> Go Back
