<!– Class –> This class represents a style based on class break values.
The ClassBreakStyle allows you to change the way features are drawn based on their data values. It is often useful for you to display features differently based on ranges of numeric values. For example, you may have a states ShapeFile that has the populations of each state as part of its data. You may then want to color states differently based on their population. The ClassBreakStyle allows you to do this.
How class breaks work:
You add a number of ClassBreak classes to the ClassBreak collection. The numeric values of the breaks are important and you must place the breaks in numerical order. For example, break 0 must be added before break 100. In each ClassBreak, you specify the style you want to represent that break. Additionally, in the ColumnName property, you specify the name of the column where we will find the data used to compare the breaks. The column name must point to a column that is numeric.
When we proceed to draw the style, we look through the ClassBreaks and select the ClassBreak that is where the features column data is greater than and closest to the break value.
Example:
Feature Value = 42
ClassBreak1.Value = 0 ClassBreak2.Value = 20 ClassBreak3.Value = 40 ClassBreak4.Value = 60
In this case, the break closest to the feature value without exceeding it is ClassBreak3(40). If the feature value had been less than zero, nothing would have been drawn. If the feature value were 1000, then ClassBreak4 would draw.
If you wanted to represent a value that is less then zero, you could do that as shown in the sample below.
Feature Value = -1
ClassBreak1.Value = Double.Min ClassBreak2.Value = 0 ClassBreak3.Value = 20 ClassBreak4.Value = 40
In this example, the first class break would be used.
ClassBreakStyle | This is the constructor for this class. | ||
ClassBreakStyle | String | This is the constructor for this class. | |
ClassBreakStyle | String, BreakValueInclusion | This is the constructor for this class. | |
ClassBreakStyle | String, BreakValueInclusion, Collection<ClassBreak> | This is the constructor for this class. |
CloneDeep | Style | Create a copy of style using the deep clone process. | |
Draw | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
Draw | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
DrawSample | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
DrawSample | GeoCanvas | Style | |
GetRequiredColumnNames | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
CloneDeepCore | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
DrawCore | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
DrawSampleCore | GeoCanvas, DrawingRectangleF | Style(overriden) | |
GetRequiredColumnNamesCore | Style(overriden) | This method returns the column data for each feature that is required for the style to properly draw. | |
BreakValueInclusion | BreakValueInclusion | This property gets and sets the value of if the break values are included in the break calculation. | |
ClassBreaks | Collection<ClassBreak> | This property gets the collection of class breaks. | |
ColumnName | String | This property gets and sets the column name in the FeatureSource where the data will be found for each feature. | |
Filters | Collection<String> | Style | |
IsActive | Boolean | Style | This property gets and sets the active status of the style. |
Name | String | Style | This property gets and set the name of the style. |
RequiredColumnNames | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
FiltersCore | Collection<String> | Style |
This constructor allows you to specify the column name of the column that will be used for the break values.
| columnName | String<!– System.String –> | This parameter is the column name of the column that will be used for the break values. |
This constructor allows you to specify the column name of the column that will be used for the break values. It also lets you specify whether the break value is included in the class break calculation.
| breakValueInclusion | BreakValueInclusion<!– ThinkGeo.MapSuite.PortableCore.BreakValueInclusion –> | This parameter lets you specify whether the break value is included in the class break calculation. |
| classBreaks | Collection<ClassBreak><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.ClassBreak} –> | The parameter represents the class break that will determine which style to be used on the break values. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works. |
| Style<!– ThinkGeo.MapSuite.PortableCore.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.PortableCore.Style –> Go Back
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
| labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
| shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
| drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –> |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.PortableCore.Style(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of the column names that it needs. |
Example: If you have a class break value set to 100 and the break value is included, then 100 is included for this break. If you set the value to excluded, then 100 would match with the break below 100 instead.
<!– ThinkGeo.MapSuite.PortableCore.ClassBreakStyle –> Go Back
The class breaks determine which style to use, based on the break values.
You use this property to set the name of the column where the numeric data is stored for your features.
