thinkgeo.mapsuite.mvcedition.wmtsoverlay
ThinkGeo.MapSuite.MvcEdition.WmtsOverlay
<!– Class –>
Public MethodWmtsOverlay
Public MethodWmtsOverlay String
Public MethodWmtsOverlay String, IEnumerable<Uri>
Public MethodWmtsOverlay String, IEnumerable<Uri>, WmtsSeverEncodingType
Public MethodFromJson String Overlay Load this object from a json string.
Public MethodGetType Object
Public MethodToJson Overlay Returns a JSON string which contains the information for creating an overlay at the client side.
Public MethodToString Object
Protected MethodRegisterJavaScriptLibraryCore Page Overlay Registers a Javascript library URL string to the client HTML page.
Public PropertyActiveLayerName String
Public PropertyActiveStyleName String
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay Gets or sets the time interval in which the MarkerOverlay refreshes itself.
Public PropertyId String Overlay Gets the identifier for the overlay to be found.
Public PropertyIsBaseOverlay Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyIsVisibleInOverlaySwitcher Boolean Overlay Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Public PropertyName String Overlay Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Public PropertyOnClientAutoRefreshTick String Overlay Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed.
Public PropertyOpacity Single Overlay Gets or sets the opacity level of the overlay.
Public PropertyOutputFormat String
Public PropertyParameters Dictionary<String,String>
Public PropertyServerUris Collection<Uri>
Public PropertyTileMatrixBoundingBox RectangleShape
Public PropertyTileMatrixIds Collection<String>
Public PropertyTileMatrixSetName String
Public PropertyTileMatrixUpperLeftPoint PointShape
Public PropertyWmtsSeverEncodingType WmtsSeverEncodingType
Protected PropertyOverlayType String Overlay(overriden) Gets a string that indicates the overlay type.
WmtsOverlay()
Name Type Description
Go Back
WmtsOverlay(String)
id String<!– System.String –>
Go Back
WmtsOverlay(String, IEnumerable<Uri>)
serverUris IEnumerable<Uri><!– System.Collections.Generic.IEnumerable{System.Uri} –>
Go Back
WmtsOverlay(String, IEnumerable<Uri>, WmtsSeverEncodingType)
wmtsSeverEncodingType WmtsSeverEncodingType<!– ThinkGeo.MapSuite.Core.WmtsSeverEncodingType –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string which is used to create an overlay at the client side.
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page Page<!– System.Web.UI.Page –> The page object that is used for registering the javascript library.
ActiveLayerName
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.WmtsOverlay –> Go Back
ActiveStyleName
Return Type
Attribution
Return Type
AutoRefreshInterval
Return Type
TimeSpan<!– System.TimeSpan –>
Id
Return Type
IsBaseOverlay
Return Type
IsVisible
Return Type
Return Type
Return Type
Return Type
Opacity
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type
Single<!– System.Single –>
OutputFormat
Return Type
Return Type
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –>
ServerUris
Return Type
Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –>
Return Type
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
TileMatrixIds
Return Type
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
TileMatrixSetName
Return Type
Return Type
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
Return Type
OverlayType
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) –> Go Back
thinkgeo.mapsuite.mvcedition.wmtsoverlay.1440040132.txt.gz · Last modified: 2015/09/21 03:36 (external edit)
