<!– Class –> This class controls the cachablity of the map control at the server side.
The <strong>ServerCache</strong> object contains information for caching map images at the server side. When you set the <strong>CacheDirectory</strong>, the server cache is automatically turned on. A map image only needs to be generated once and then saved to the folder specified by the <strong>CacheDirectory</strong>. Later, when the map image is revisited, it is retrieved from the cache folder. Using the server cache will greatly increase the responsiveness of the map, but it is only suitable for a static map.
*System.Object **ThinkGeo.MapSuite.MvcEdition.ServerCache
ServerCache | Initializes a new instance of the ServerCache class. | ||
ServerCache | String | Initializes a new instance of the ServerCache class with the specified cache directory. |
CacheDirectory | String | Gets or sets a string that represents the directory of the cache folder. | |
CacheId | String | Gets or sets a string which is used to retrieve the cached images. |
| cacheDirectory | String<!– System.String –> | The directory string that indicates where the cache images are saved to. |
<!– ThinkGeo.MapSuite.MvcEdition.ServerCache –> Go Back
The <strong>CacheId</strong> is actually the name of a sub-folder of the cache folder to which images with the same CacheId are saved. When you set the same CacheId in different pages, the map images of these pages will be saved and retrieved from the same folder. Thus you can share cache images between pages.
