thinkgeo.mapsuite.mvcedition.popupsetting_2
ThinkGeo.MapSuite.MvcEdition.PopupSetting<TPopup,TPopupSetting>
A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
    • ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase<TPopup,TPopupSetting>
      • ThinkGeo.MapSuite.MvcEdition.PopupSetting<TPopup,TPopupSetting>
PopupSetting`2()
Initializes a new instance of the PopupSetting class.
PopupSetting`2(TPopup)
  • popup
    • Type:TPopup
Position(PointShape)
Set position for Element property and retun the PopupSetting
  • Type:TPopupSetting
  • Description:The setting of PopupSetting itself
  • position
    • Description:A position for Element property
Width(Int32)
Set width for Element property and retun the PopupSetting
  • width
    • Description:A width for Element property
Height(Int32)
Set height for Element property and retun the PopupSetting
  • height
    • Description:A height for Element property
IsVisible(Boolean)
Set isVisible for Element property and retun the PopupSetting
  • isVisible
    • Description:A isVisible for Element property
Opacity(Single)
Set opacity for Element property and retun the PopupSetting
  • opacity
    • Type:Single
    • Description:A opacity for Element property
AutoSize(Boolean)
Set autoSize for Element property and retun the PopupSetting
  • autoSize
    • Description:A autoSize for Element property
AutoPan(Boolean)
Set autoPan for Element property and retun the PopupSetting
  • autoPan
    • Description:A autoPan for Element property
HasCloseButton(Boolean)
Set hasCloseButton for Element property and retun the PopupSetting
  • hasCloseButton
    • Description:A hasCloseButton for Element property
OffsetXInPixels(Int32)
Set offsetXInPixels for Element property and retun the PopupSetting
  • offsetXInPixels
    • Description:A offsetXInPixels for Element property
OffsetYInPixels(Int32)
Set offsetYInPixels for Element property and retun the PopupSetting
  • offsetYInPixels
    • Description:A offsetYInPixels for Element property
Element
  • Type:TPopup
thinkgeo.mapsuite.mvcedition.popupsetting_2.1442806539.txt.gz · Last modified: 2015/09/21 03:35 by admin
