<!– Class –> Represents an overlay object that gets images from the Google Maps server.
The GoogleOverlay registers Google's Javascript library to the page and gets Google's map images as the background of the map. The GoogleOverlay can only be the base overlay of the map, over which other overlays are laid.
GoogleOverlay | Initialize an instance of the GoogleOverlay class. | ||
GoogleOverlay | String | Initialize an instance of the GoogleOverlay class with the overlay identifier specified. | |
GoogleOverlay | GoogleMapType | Initialize an instance of the GoogleOverlay class with the overlay identifier | |
GoogleOverlay | String, GoogleMapType | Initialize an instance of the GoogleOverlay class with the overlay identifier and the Google map type specified. |
MemberwiseClone | Object | ||
RegisterJavaScriptLibraryCore | Page | Overlay(overriden) | Registers the Google Javascript library URL string to the client HTML page. |
Attribution | String | Overlay | |
AutoRefreshInterval | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
CenterOnStreetView | Boolean | ||
GoogleMapType | GoogleMapType | Gets or sets a value that determines which type of Google Map to use. | |
GoogleStreetView | GoogleStreetView | ||
Id | String | Overlay | Gets the identifier for the overlay to be found. |
IsBaseOverlay | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
IsVisible | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
IsVisibleInOverlaySwitcher | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
JavaScriptLibraryUri | Uri | Gets or sets a URI object for loading the Google Maps Javascript library. | |
Name | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
OnClientAutoRefreshTick | String | Overlay(overriden) | Don't support auto tick event by default. |
Opacity | Single | Overlay | Gets or sets the opacity level of the overlay. |
TiltEnabled | Boolean | ||
TrafficEnabled | Boolean |
OverlayType | String | Overlay(overriden) | Gets a string that indicates the overlay type. |
| id | String<!– System.String –> | The identifier string of the overlay. |
| googleMapType | GoogleMapType<!– ThinkGeo.MapSuite.MvcEdition.GoogleMapType –> | The map type of this GoogleOverlay. |
| id | String<!– System.String –> | The identifier string of the Overlay. |
Load this object from a json string.
| jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) –> Go Back
Returns a JSON string which contains the information for creating an overlay at the client side.
| String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> Go Back
| page | Page<!– System.Web.UI.Page –> | The page object that contains the map. |
| TimeSpan<!– System.TimeSpan –> |
<!– ThinkGeo.MapSuite.MvcEdition.GoogleOverlay –> Go Back
| GoogleStreetView<!– ThinkGeo.MapSuite.MvcEdition.GoogleStreetView –> |
| Uri<!– System.Uri –> |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
