<!– Class –> A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.ContextMenuItemSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.ContextMenuItem ThinkGeo.MapSuite.MvcEdition.ContextMenuItemSetting
ContextMenuItemSetting | ContextMenuItem | Initializes a new instance of the ContextMenuItemSetting class. |
CssClass | String | Set css Class for Element property and retun the ContextMenuItemSetting | |
HoverCssClass | String | Set hover Css Class for Element property and retun the ContextMenuItemSetting | |
Id | String | Set Id for Element property and retun the ContextMenuItemSetting | |
InnerHtml | String | Set inner Html for Element property and retun the ContextMenuItemSetting | |
MenuItems | Action<ContextMenuItemCollection> | Initializes a new instance of the ContextMenuItemSetting class. | |
OnClientClick | String | Set client Click Script for Element property and retun the ContextMenuItemSetting | |
Element | ContextMenuItem | MvcElementSettingBase<ContextMenuItem,ContextMenuItemSetting> |
| contextMenuItem | ContextMenuItem<!– ThinkGeo.MapSuite.MvcEdition.ContextMenuItem –> | the context menu item which will be assigned to Element property |
| ContextMenuItemSetting<!– ThinkGeo.MapSuite.MvcEdition.ContextMenuItemSetting –> | The setting of ContextMenuItem itself |
| cssClass | String<!– System.String –> | A css Class for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.ContextMenuItemSetting –> Go Back
| hoverCssClass | String<!– System.String –> | A id for Element property |
| id | String<!– System.String –> | A id for Element property |
| innerHtml | String<!– System.String –> | A inner Html for Element property |
| addItemsAction | Action<ContextMenuItemCollection><!– System.Action{ThinkGeo.MapSuite.MvcEdition.ContextMenuItemCollection} –> | a method that takes ContextMenuItemCollection to do some settings. |
| clientClickScript | String<!– System.String –> | A client Click Script for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.ContextMenuItem,ThinkGeo.MapSuite.MvcEdition.ContextMenuItemSetting} –> Go Back
