<!– Class –> This class represents a menu item of the ContextMenu control.
*System.Object **ThinkGeo.MapSuite.MvcEdition.ContextMenuItem
ContextMenuItem | Initializes a new instance of the ContextMenuitem. class. | ||
ContextMenuItem | String | Initializes a new instance of the ContextMenuitem. class with the innerHtml specified. | |
ContextMenuItem | String, String | Initializes a new instance of the ContextMenuitem. class with the innerHtml and CSS class string specified. | |
ContextMenuItem | String, String, String | Initializes a new instance of the ContextMenuitem. class with innerHtml, CSS class and hover CSS class specified. | |
ContextMenuItem | String, String, String, String | Initializes a new instance of the ContextMenuitem. class with innerHtml, CSS class and hover CSS class specified. |
CssClass | String | Gets or sets the Cascading Style Sheet (CSS) class name string that affects the appearance of the context menu item. | |
HoverCssClass | String | Gets or sets the Cascading Style Sheet (CSS) class name string that applies when the mouse hovers over the menu item. | |
Id | String | Gets the identifier of the context menu item. | |
InnerHtml | String | Gets or sets the content HTML of the context menu item. | |
MenuItems | GeoKeyedCollection<ContextMenuItem> | Gets the menu item collection of the context menu item. | |
OnClientClick | String | Gets or sets the client-side script that executes when a context menu item's Click event is raised. |
| innerHtml | String<!– System.String –> | The innerHtml of the context menu item. |
| cssClass | String<!– System.String –> | The CSS class of the context menu item. |
| hoverCssClass | String<!– System.String –> | The CSS class of the context menu item when the mouse is hovering over it. |
| id | String<!– System.String –> | The id of the context menu item. |
Load this object from a json string.
| jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.ContextMenuItem –> Go Back
Returns a JSON string that has information for creating the context menu item at the client side.
| String<!– System.String –> | A JSON string for creating the context menu item at the client side. |
| GeoKeyedCollection<ContextMenuItem><!– ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection{ThinkGeo.MapSuite.MvcEdition.ContextMenuItem} –> |
There is a default parameter:e, which includes one parameter: “worldXY”
