thinkgeo.mapsuite.mvcedition.arcgisserverrestoverlay
ThinkGeo.MapSuite.MvcEdition.ArcGISServerRestOverlay
This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
    • ThinkGeo.MapSuite.MvcEdition.Overlay
      • ThinkGeo.MapSuite.MvcEdition.ArcGISServerRestOverlay
ArcGISServerRestOverlay()
Initialize an instance of the ArcGISServerRestOverlay class with none parameter.
ArcGISServerRestOverlay(String)
Initialize an instance of the ArcGISServerRestOverlay class.
  • id
    • Description:The identifier string of the ArcGISServerRestOverlay.
ArcGISServerRestOverlay(String,Uri)
  • id
  • serverUri
    • Type:Uri
    • Description:The uri of the ArcGIS REST SERVER
ArcGISServerRestOverlay(Uri)
  • serverUri
    • Type:Uri
ArcGISServerRestOverlay(String,Uri,TileType)
  • id
  • serverUri
    • Type:Uri
  • tileType
    • Type:TileType
    • Description:The Tile Type of the layer
FromJson(String)
Load this object from a json string.
  • jsonString
    • Description:a json string
ToJson()
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
Gets a dictionary whose items will be passed to the ArcGIS REST Server server as parameters.
Projection
Gets or sets a string that will be sent to the ArcGIS REST server to get the images in the specific projection.
TileWidth
Gets or sets the width of each tile, if the WmsOverlay uses tiling.
TileHeight
Gets or sets the height of each tile, if the WmsOverlay uses tiling.
TransitionEffect
Gets or sets the transition effect to use when the map is zoomed.
TransitionEffectDelayInMilliseconds
TileType
Gets or sets whether or not the ArcGISServerRestOverlay uses tiling.
ServerUri
Gets or sets the URI that specifies the locations of the ArcGIS Rest servers.
  • Type:Uri
OnClientAutoRefreshTick
Don't support auto tick event by default.
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
IsBaseOverlay
Id
AutoRefreshInterval
  • Type:TimeSpan
Attribution
OverlayType
Gets a string that indicates the overlay type.
ERQ=
thinkgeo.mapsuite.mvcedition.arcgisserverrestoverlay.1442806335.txt.gz · Last modified: 2015/09/21 03:32 by admin
