<!– Class –> A setting for AdornmentOverlay that contains APIs to set properties of AdornmentOverlaySetting using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.AdornmentOverlay PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.OverlaySetting`2[[ThinkGeo.MapSuite.MvcEdition.AdornmentOverlay **ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting
![]() | AdornmentOverlay | Initializes a new instance of the AdornmentOverlaySetting class. |
![]() | TimeSpan | OverlaySetting<AdornmentOverlay,AdornmentOverlaySetting> | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | String | OverlaySetting<AdornmentOverlay,AdornmentOverlaySetting> | |
![]() | Boolean | OverlaySetting<AdornmentOverlay,AdornmentOverlaySetting> | |
![]() | AdornmentLayer | Set adornment layer for Element property and retun the AdornmentOverlaySetting | |
![]() | String, AdornmentLayer | Set adornment layer with specific key for Element property and retun the AdornmentOverlaySetting | |
![]() | Single | OverlaySetting<AdornmentOverlay,AdornmentOverlaySetting> | |
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | AdornmentOverlay | MvcElementSettingBase<AdornmentOverlay,AdornmentOverlaySetting> |
Name | Type | Description |
adornmentOverlay | AdornmentOverlay<!– ThinkGeo.MapSuite.MvcEdition.AdornmentOverlay –> |
Return Type | Description |
AdornmentOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting –> |
timeSpan | TimeSpan<!– System.TimeSpan –> |
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySetting{ThinkGeo.MapSuite.MvcEdition.AdornmentOverlay,ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting} –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
id | String<!– System.String –> |
isBaseOverlay | Boolean<!– System.Boolean –> |
isVisible | Boolean<!– System.Boolean –> |
isVisibleInOverlaySwitcher | Boolean<!– System.Boolean –> |
AdornmentOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting –> | The setting of AdornmentOverlaySetting itself |
layer | AdornmentLayer<!– ThinkGeo.MapSuite.Core.AdornmentLayer –> | A adornment layer for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting –> Go Back
key | String<!– System.String –> | A key string for adornment layer |
name | String<!– System.String –> |
clientTickFunctionName | String<!– System.String –> |
opacity | Single<!– System.Single –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.AdornmentOverlay,ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting} –> Go Back
