<!– Class –> This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
![]() | Initialize an instance of the AdornmentOverlay class. | ||
![]() | String | Initialize an instance of the AdornmentOverlay class with the overlay identifier specified. |
![]() | GeoCanvas | Draw all of the layers to the image object using the parameters specified. | |
![]() | Object | Object | |
![]() | String | Overlay | Load this object from a json string. |
![]() | Object | ||
![]() | Object | ||
![]() | Overlay | Returns a JSON string which contains the information for creating an overlay at the client side. | |
![]() | Object |
![]() | GeoCanvas | This method overrides the DrawCore logic in the Overlay base class. Draw all of the AdornmentLayers to the image object using the parameters specified. | |
![]() | Object | ||
![]() | Object | ||
![]() | Page | Overlay | Registers a Javascript library URL string to the client HTML page. |
![]() | String | Overlay | |
![]() | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
![]() | String | Overlay | Gets the identifier for the overlay to be found. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
![]() | GeoCollection<AdornmentLayer> | This property gets a collection of the AdornmentLayers that are added to the AdornmentOverlay. | |
![]() | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
![]() | String | Overlay | Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed. |
![]() | Single | Overlay | Gets or sets the opacity level of the overlay. |
![]() | String | Overlay(overriden) | Gets a string that indicates the overlay type. |
Name | Type | Description |
id | String<!– System.String –> | The identifier string used to retrieve the overlay for collection. |
Return Type | Description |
Void<!– System.Void –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter specifies the target canvas to draw the current AdornmentOverlay on. |
<!– ThinkGeo.MapSuite.MvcEdition.AdornmentOverlay –> Go Back
jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
Return Type |
Return Type |
TimeSpan<!– System.TimeSpan –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
GeoCollection<AdornmentLayer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.AdornmentLayer} –> |
Return Type |
Return Type |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type |
Single<!– System.Single –> |
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) –> Go Back
