thinkgeo.mapsuite.mapsuitegeocoder.usageocoder
ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder
This class is for United States Geocoding.
    • ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder
      • ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder
UsaGeocoder()
This is the constructor of this class.
UsaGeocoder(String)
  • dataPath
    • Description:The path to the Geocoder data folder.
UsaGeocoder(String,MatchMode)
  • dataPath
  • matchMode
    • Type:MatchMode
    • Description:This parameter represents the match mode.
UsaGeocoder(String,StreetNumberMatchingMode)
  • dataPath
  • streetNumberMatchingMode
UsaGeocoder(String,MatchMode,StreetNumberMatchingMode)
  • dataPath
  • matchMode
    • Type:MatchMode
Match(String,String)
This method matches the specified street address and zip code.
  • Type:Collection<GeocoderMatch>
  • Description:The matched results within a collection of GeocoderMatch.
  • streetAddress
    • Description:This parameter is the street address to match.
  • zip
    • Description:This parameter is the zip code to match.
Match(String,String,String)
This method matches the specified street address, city and state.
  • streetAddress
  • city
    • Description:This parameter is the city to match.
  • state
    • Description:This parameter is the state to match.
Open()
Close()
Match(String)
  • sourceText
OpenCore()
Opens all of the internal MatchingPlugins.
MatchCore(String)
This method matches the source text.
This method calls the match method of each MatchingPlugIn object and then evaluates the match results from each MatchingPlugIn object to get the best match items.
  • sourceText
    • Description:The source text to match.
EvaluateMatchResults(IEnumerable<GeocoderMatch>)
This method evaluates the MatchItems from different MatchingPlugIns and gets the final MatchResult. This is a concrete wrapper for EvaluateMatchResultsCore.
  • Description:The evaluated results within a collection of GeocoderMatch.
  • sourceMatchItems
    • Type:IEnumerable<GeocoderMatch>
    • Description:The collection of GeocoderMatch.
EvaluateMatchResultsCore(IEnumerable<GeocoderMatch>)
This method evaluates the MatchItems from different MatchingPlugIns and gets the final MatchResult. This method adds all MatchItems into one list, then loops though and evaluates every two MatchItems, sorts the MatchItems by the MatchRanking property of the MatchItem, and finally adds them to MatchResult. When evaluating two MatchItems, if the name-value pairs of the two MatchItems have the same key and that key is in the compare key array, just compare the value. If the values are equal then use the MatchRanking plus the RankingMultiplier.
  • sourceMatchItems
    • Description:The collection of MatchItems.
CloseCore()
MatchMode
This parameter represents the street number matching mode mode.
DataPath
MatchingPlugIns
thinkgeo.mapsuite.mapsuitegeocoder.usageocoder.1442819051.txt.gz · Last modified: 2015/09/21 07:04 by admin
