<!– Class –> This is the derived class of the class MatchingPlugIn for matching PostCode.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin</a>
*System.Object ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin *ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin
PostcodeDbfMatchingPlugin | This is the constructor of this class. | ||
PostcodeDbfMatchingPlugin | String | This is the constructor of this class. |
Close | MatchingPlugin | This method closes the MatchingPlugin. This method is the concrete wrapper for CloseCore. | |
Dispose | Releases all resources used by the PostCodeDbfMatchingPlugin. | ||
Match | String | MatchingPlugin | This method matches the source text and returns a collection of GeocoderMatch. This method is the concrete wrapper for MatchCore. It firstly formalizes the input sourceText, gets the formalized results and matches them using MatchCore one by one, then returns all of the results within a collection. |
Open | MatchingPlugin | This method opens the MatchingPlugin for use. This method is the concrete wrapper for OpenCore. | |
CloseCore | MatchingPlugin(overriden) | This method closes the PostCodeDbfMatchingPlugin. | |
Finalize | Object(overriden) | This method is automatically called after an object becomes inaccessible, unless the object has been exempted from finalization by a call to SuppressFinalize. | |
Formalize | String | MatchingPlugin | This method formalizes the source text. This method is the concrete wrapper of FormalizeCore. |
FormalizeCore | String | MatchingPlugin | This method formalizes the source text. |
MatchCore | String | MatchingPlugin(overriden) | This method matches the source text in PostCode DBF file. |
MemberwiseClone | Object | ||
OpenCore | MatchingPlugin(overriden) | This method opens the PostCodeDbfMatchingPlugin. |
DataPath | String | This property is the path to the Geocoder data folder. | |
RankingMultiplier | Int32 | MatchingPlugin | This property is the ranking multipier for GeocoderMatch. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#PostcodeDbfMatchingPlugin.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#PostcodeDbfMatchingPlugin.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#PostcodeDbfMatchingPlugin.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#PostcodeDbfMatchingPlugin.28String.29</a>
| dataPath | String<!– System.String –> | The path to the Geocoder data folder. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Close.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Close.28.29</a>
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Dispose.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Dispose.28.29</a>
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Match.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Match.28String.29</a>
| Collection<GeocoderMatch><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} –> | A collection of GeocoderMatch. |
| sourceText | String<!– System.String –> | The source text to match. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Open.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Open.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#CloseCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#CloseCore.28.29</a>
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Formalize.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#Formalize.28String.29</a>
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The collection of formalized strings. |
| sourceText | String<!– System.String –> | The source text to formalize. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#FormalizeCore.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#FormalizeCore.28String.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#MatchCore.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#MatchCore.28String.29</a>
| Collection<GeocoderMatch><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} –> | The collection of MatchItem objects. |
| sourceText | String<!– System.String –> | This parameter is the source text to match. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#OpenCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#OpenCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#DataPath” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#DataPath</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#RankingMultiplier” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin#RankingMultiplier</a>
