<!– Class –> This class is the base class for Geocoding.
This class provides a basic implementation for Geocoding that contains a MatchingPlugIn object collection. You can inherit from it for specific Geocoding requirements by adding MatchingPlugIn objects.
*System.Object ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder *ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder
Close | This method closes the Geocoder and releases all of its resources. | ||
Match | String | This method matches the input source text. | |
Open | This method opens the Geocoder so that it is initialized and ready to use. | ||
CloseCore | This method closes the Geocoder and releases all of its resources. This method loops through each MatchingPlugIn object in the MatchingPlugIns collection to call their Close() method. | ||
MatchCore | String | This method matches the input source text. | |
MemberwiseClone | Object | ||
OpenCore | This method opens the Geocoder so that it is initialized and ready to use. This method loops through each MatchingPlugIn object in the MatchingPlugIns collection to call their Open() method. |
DataPath | String | The path to the Geocoder data folder. | |
MatchingPlugIns | Collection<MatchingPlugin> | The collection of MatchingPlugIns. |
Constructor of this class.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Geocoder.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Geocoder.28.29</a>
Geocoder constructor.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Geocoder.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Geocoder.28String.29</a>
| dataPath | String<!– System.String –> | The path to the Geocoder data folder. |
This method is the concrete wrapper for the virtual method CloseCore.
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#GetType.28.29</a>
This method is the concrete wrapper for the virtual method MatchCore.
| Collection<GeocoderMatch><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} –> | A collection of GeocoderMatch. |
| sourceText | String<!– System.String –> | Source text to match. |
This method is the concrete wrapper for the virtual method OpenCore.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#CloseCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#CloseCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#Finalize.28.29</a>
This method loops through each MatchingPlugIn objects in MatchingPlugIns collection, calls their Match() method and gets all GeocoderMatches.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#OpenCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#OpenCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#DataPath” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#DataPath</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#MatchingPlugIns” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder#MatchingPlugIns</a>
| Collection<MatchingPlugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin} –> |
