thinkgeo.mapsuite.iosedition.trackendingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.TrackEndingTrackInteractiveOverlayEventArgs
<!– Class –> Provides data for the TrackEnding. event.
Public MethodTrackEndingTrackInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodTrackEndingTrackInteractiveOverlayEventArgs BaseShape, Boolean This is the commonly used constructor.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean This property gets or sets the action to be canceled or not.
Public PropertyTrackShape BaseShape This property gets or sets the shape to be tracking out.
TrackEndingTrackInteractiveOverlayEventArgs()
Name Type Description
Go Back
TrackEndingTrackInteractiveOverlayEventArgs(BaseShape, Boolean)
shape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This parameter specified the shape to be tracking out.
cancel Boolean<!– System.Boolean –> This parameter specified the cancel property.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.iOSEdition.TrackEndingTrackInteractiveOverlayEventArgs –> Go Back
TrackShape
Return Type
thinkgeo.mapsuite.iosedition.trackendingtrackinteractiveoverlayeventargs.1440040131.txt.gz · Last modified: 2015/09/21 08:34 (external edit)
