Represents an TileView that maintains one tile.
This constructor is used to programmatically create a new instance of UIImageView with the specified dimension in the frame. The object will only be displayed once it has been added to a view hierarchy by calling AddSubview in a containing view.This constructor is not invoked when deserializing objects from storyboards or XIB filesinstead the constructor that takes an NSCoder parameter is invoked.
ConvertPointFromCoordinateSpace(CGPoint,IUICoordinateSpace)
ConvertPointFromView(CGPoint,UIView)
ConvertPointToCoordinateSpace(CGPoint,IUICoordinateSpace)
ConvertPointToView(CGPoint,UIView)
ConvertRectFromCoordinateSpace(CGRect,IUICoordinateSpace)
ConvertRectFromView(CGRect,UIView)
ConvertRectToCoordinateSpace(CGRect,IUICoordinateSpace)
ConvertRectToView(CGRect,UIView)
DecodeRestorableState(NSCoder)
DrawViewHierarchy(CGRect,Boolean)
EncodeRestorableState(NSCoder)
GetConstraintsAffectingLayout(UILayoutConstraintAxis)
InsertSubviewAbove(UIView,UIView)
InsertSubviewBelow(UIView,UIView)
InvalidateIntrinsicContentSize()
RemoveConstraint(NSLayoutConstraint)
SetContentCompressionResistancePriority(Single,UILayoutConstraintAxis)
SetContentHuggingPriority(Single,UILayoutConstraintAxis)
MakeTextWritingDirectionLeftToRight(NSObject)
MotionCancelled(UIEventSubtype,UIEvent)
MotionEnded(UIEventSubtype,UIEvent)
TouchesCancelled(NSSet,UIEvent)
UpdateUserActivityState(NSUserActivity)
PerformSelector(Selector,NSThread,NSObject,Boolean,NSString[])
PerformSelector(Selector,NSObject,NSObject)
RemoveObserver(NSObject,NSString,IntPtr)
RemoveObserver(NSObject,String,IntPtr)
RemoveObserver(NSObject,NSString)
RemoveObserver(NSObject,String)
SetValueForKeyPath(NSObject,NSString)
SetValueForUndefinedKey(NSObject,NSString)
SetValuesForKeysWithDictionary(NSDictionary)
WillChange(NSString,NSKeyValueSetMutationKind,NSSet)
InvokeOnMainThread(Selector,NSObject)
BeginInvokeOnMainThread(Action)
AddObserver(String,NSKeyValueObservingOptions,Action<NSObservedChange>)
AddObserver(NSString,NSKeyValueObservingOptions,Action<NSObservedChange>)
AddObserver(NSObject,String,NSKeyValueObservingOptions,IntPtr)
DidChange(NSString,NSKeyValueSetMutationKind,NSSet)
PerformSelector(Selector,NSObject,Double,NSString[])
PerformSelector(Selector,NSObject,Double)
PerformSelector(Selector,NSThread,NSObject,Boolean)
Releases the resources used by the UIImageView object.
This Dispose method releases the resources used by the UIImageView class.This method is called by both the Dispose() method and the object finalizer (Finalize). When invoked by the Dispose method, the parameter disposing is set to and any managed object references that this object holds are also disposed or released; when invoked by the object finalizer, on the finalizer thread the value is set to . Calling the Dispose method when you are finished using the UIImageView ensures that all external resources used by this managed object are released as soon as possible. Once you have invoked the Dispose method, the object is no longer useful and you should no longer make any calls to it. For more information on how to override this method and on the Dispose/IDisposable pattern, read the ``Implementing a Dispose Method'' document at http:msdn.microsoft.com/en-us/library/fs2xkftw.aspx
