<!– Class –> This class represents an NativeImage object for iOS platform.
*System.Object **ThinkGeo.MapSuite.iOSEdition.CGNativeImage
CGNativeImage | Initializes a new instance of the class. | ||
CGNativeImage | Single, Single | Initializes a new instance of the class. | |
CGNativeImage | Stream | Initializes a new instance of the class. | |
CGNativeImage | UIImage | Initializes a new instance of the class. |
BeginInitCore | Begins the initialize core to draw image. | ||
Dispose | Boolean | Releases unmanaged and - optionally - managed resources. | |
EndInitCore | Ends the initialize core. | ||
Finalize | Object(overriden) | Finalizes an instance of the class. | |
| width | Single<!– System.Single –> | The width. |
| height | Single<!– System.Single –> | The height. |
| imageStream | Stream<!– System.IO.Stream –> | The image stream. |
| uiImage | UIImage<!– MonoTouch.UIKit.UIImage –> | The UI image. |
Begins the initialize to draw image.
<!– ThinkGeo.MapSuite.iOSEdition.CGNativeImage –> Go Back
Performs application-defined tasks associated with freeing, releasing, or resetting unmanaged resources.
Ends the initialize.
| p | Boolean<!– System.Boolean –> | true to release both managed and unmanaged resources; false to release only unmanaged resources. |
Gets or sets the context.
| CGContext<!– MonoTouch.CoreGraphics.CGContext –> |
Gets or sets the height for NativeImage.
Gets or sets the UI image.
Gets or sets the width for NativeImage.
