thinkgeo.mapsuite.desktopedition.trackendingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs
Provides data for the TrackEnding event.
      • ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs
TrackEndingTrackInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
TrackEndingTrackInteractiveOverlayEventArgs(BaseShape,Boolean)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs#TrackEndingTrackInteractiveOverlayEventArgs.28BaseShape.2C_Boolean.29
  • shape
    • Type:BaseShape
    • Description:This parameter specifies the shape to be tracking out.
  • cancel
    • Description:This parameter specifies the cancel property.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndingTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29
TrackShape
  • This property gets or sets the shape to be tracking out.
thinkgeo.mapsuite.desktopedition.trackendingtrackinteractiveoverlayeventargs.1442966520.txt.gz · Last modified: 2015/09/23 00:02 by admin
