thinkgeo.mapsuite.desktopedition.sessionfilebitmaptilecache
ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache
This class is a concrete class that inherits from FileBitmapTileCache. In this class, the tiles will be marked as obsolete when you call the ClearCache method and will be deleted in a background thread.
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.BitmapTileCache
        • ThinkGeo.MapSuite.Core.FileBitmapTileCache
          • ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache
SessionFileBitmapTileCache()
  • This is the default constructor.
  • If you use this constructor, you must set the properties manually.
SessionFileBitmapTileCache(String)
  • This is the overloads constructor.
  • If you use this constructor, the other properties are set with default values.
  • cacheDirectory
    • Description:This parameter specifies the directory of the tile cache.
SessionFileBitmapTileCache(String,String)
  • cacheDirectory
  • cacheId
    • Description:This parameter specifies the cache ID of the tile cache.
SessionFileBitmapTileCache(String,String,TileImageFormat,TileMatrix)
  • This is the constructor with all the parameters needed passed in.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#SessionFileBitmapTileCache.28String.2C_String.2C_TileImageFormat.2C_TileMatrix.29
  • cacheDirectory
  • cacheId
    • Description:This parameter specifies the cache IF of the tile cache.
  • imageFormat
    • Description:This parameter specifies the image format of the tile cahce.
  • tileMatrix
    • Description:This parameter specifies the tile matrix of the tile cache.
ClearCache(TimeSpan)
  • tileExpiration
    • Type:TimeSpan
ClearCache(Double)
  • maxSizeInMegabytes
ClearCache(TimeSpan,Double)
  • tileExpiration
    • Type:TimeSpan
GetTileImageFileNames(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetTileImageFileNames.28RectangleShape.29
  • Type:Collection<String>
GetTileImageFileName(Int64,Int64)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetTileImageFileName.28Int64.2C_Int64.29
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTile(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetTile.28RectangleShape.29
GetTile(Int64,Int64)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetTile.28Int64.2C_Int64.29
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetTiles.28RectangleShape.29
GetHigherScaleTile(RectangleShape,Double)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetHigherScaleTile.28RectangleShape.2C_Double.29
  • tileScale
SaveTile(Tile)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#SaveTile.28Tile.29
  • tile
    • Type:Tile
SaveTiles(Bitmap,RectangleShape,Boolean)
  • bitmap
    • Type:Bitmap
  • saveContainedCellsOnly
SaveTiles(Bitmap,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#SaveTiles.28Bitmap.2C_RectangleShape.29
  • bitmap
    • Type:Bitmap
DeleteTiles(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#DeleteTiles.28RectangleShape.29
DeleteTile(Tile)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#DeleteTile.28Tile.29
  • tile
    • Type:Tile
ClearCache()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#ClearCache.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetType.28.29
ClearCacheCore()
  • This method will create a new cacheId for the SessionFileBitmapTileCache and mark the original one as obsolete. The original will then be deleted in a background thread.
  • This method will not take effect when ReadOnly is set to true.
GetTileCore(Int64,Int64)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetTileCore.28Int64.2C_Int64.29
  • row
    • Type:Int64
  • column
    • Type:Int64
SaveTileCore(Tile)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#SaveTileCore.28Tile.29
  • tile
    • Type:Tile
DeleteTileCore(Tile)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#DeleteTileCore.28Tile.29
  • tile
    • Type:Tile
8xU=(String)
  • tileImageFileName
9BU=(Bitmap)
  • Type:Byte[]
  • bitmap
    • Type:Bitmap
GetHigherScaleTileCore(RectangleShape,Double)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#GetHigherScaleTileCore.28RectangleShape.2C_Double.29
  • tileScale
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#OnGottenCacheImage.28GottenCacheImageBitmapTileCacheEventArgs.29
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#OnGettingCacheImage.28GettingCacheImageBitmapTileCacheEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#MemberwiseClone.28.29
CacheDirectory
ExpirationTime
  • Type:TimeSpan
TileMatrix
TileAccessMode
NoDataTileImage
  • Type:Bitmap
LoadingTileImage
  • Type:Bitmap
ImageFormat
JpegQuality
  • Type:Int16
CacheId
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.SessionFileBitmapTileCache#CacheId
GottenCacheImage N/A
thinkgeo.mapsuite.desktopedition.sessionfilebitmaptilecache.1442909576.txt.gz · Last modified: 2015/09/22 08:12 by admin
