This class is a concrete class that inherits from FileBitmapTileCache. In this class, the tiles will be marked as obsolete when you call the ClearCache method and will be deleted in a background thread.
If you use this constructor, you must set the properties manually.
If you use this constructor, the other properties are set with default values.
SessionFileBitmapTileCache(String,String)
This is the overloads constructor.
SessionFileBitmapTileCache(String,String,TileImageFormat,TileMatrix)
This is the constructor with all the parameters needed passed in.
GetTileImageFileNames(RectangleShape)
SaveTiles(Bitmap,RectangleShape)
This method will create a new cacheId for the SessionFileBitmapTileCache and mark the original one as obsolete. The original will then be deleted in a background thread.
This method will not take effect when ReadOnly is set to true.
MergeBitmaps(IEnumerable<BitmapTile>,Double)
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
Event Arguments:GettingCacheImageBitmapTileCacheEventArgs
