thinkgeo.mapsuite.desktopedition.overlaysdrawnwpfmapeventargs
ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs
This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn.
      • ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs
OverlaysDrawnWpfMapEventArgs()
  • This is the default constructor. If you use this constructor then you need to set the required properties manually.
OverlaysDrawnWpfMapEventArgs(IEnumerable<Overlay>,RectangleShape,Object)
  • For the most updated Info for this topic, please check it here:
  • overlays
    • Type:IEnumerable<Overlay>
    • Description:This parameter is the overlays that have been drawn.
  • worldExtent
    • Description:This parameter is the wold extent that has been drawn.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs#MemberwiseClone.28.29
WorldExtent
This property gets and sets the world extent that has been drawn.
NativeImage
This property gets and sets the GeoImage or native image we have drawn on.
Overlays
This property gets the overlays you have drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawnWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto
thinkgeo.mapsuite.desktopedition.overlaysdrawnwpfmapeventargs.1442909563.txt.gz · Last modified: 2015/09/22 08:12 by admin
