thinkgeo.mapsuite.desktopedition.overlaysdrawingwinformsmapeventargs
ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs
This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
      • ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs
OverlaysDrawingWinformsMapEventArgs()
  • This is the default constructor. If you use this constructor then you need to set the required properties manually.
OverlaysDrawingWinformsMapEventArgs(IEnumerable<Overlay>,RectangleShape,Object,Boolean)
  • For the most updated Info for this topic, please check it here:
  • overlays
    • Type:IEnumerable<Overlay>
    • Description:This parameter is the overlays that will be drawing.
  • worldExtent
    • Description:This parameter is the wold extent you are drawing.
  • nativeImage
    • Description:This parameter is the native map image.
  • cancel
    • Description:This parameter specifies whether we need to cancel drawing the overlays or not.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#MemberwiseClone.28.29
Cancel
This property gets or sets whether the action will be canceled or not.
WorldExtent
This property gets and sets the world extent to be drawn.
NativeImage
This property gets and sets the GeoImage or native image we are drawing on.
Overlays
This property gets the overlays you will be drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto
thinkgeo.mapsuite.desktopedition.overlaysdrawingwinformsmapeventargs.1442909558.txt.gz · Last modified: 2015/09/22 08:12 by admin
