thinkgeo.mapsuite.desktopedition.overlaysdrawingwinformsmapeventargs
ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs
<!– Class –> This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn. This event allows you to cancel, manipulate the Layer, or draw something with the canvas before the Layer draws.
Public MethodOverlaysDrawingWinformsMapEventArgs This is a constructor for the class.
Public MethodOverlaysDrawingWinformsMapEventArgs IEnumerable<Overlay>, RectangleShape, Object, Boolean This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean This property gets or sets whether the action will be canceled or not.
Public PropertyNativeImage Object This property gets and sets the GeoImage or native image we are drawing on.
Public PropertyOverlays IEnumerable<Overlay> This property gets the overlays you will be drawing.
Public PropertyWorldExtent RectangleShape This property gets and sets the world extent to be drawn.
OverlaysDrawingWinformsMapEventArgs()
Overloads
This is the default constructor. If you use this constructor then you need to set the required properties manually.
Name Type Description
Go Back
OverlaysDrawingWinformsMapEventArgs(IEnumerable<Overlay>, RectangleShape, Object, Boolean)
Overloads
This constructor allows you to set the overlays to be drawn, the world extent and the image you are drawing on.
overlays IEnumerable<Overlay><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.DesktopEdition.Overlay} –> This parameter is the overlays that will be drawing.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the wold extent you are drawing.
nativeImage Object<!– System.Object –> This parameter is the native map image.
cancel Boolean<!– System.Boolean –> This parameter specifies whether we need to cancel drawing the overlays or not.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs –> Go Back
NativeImage
Return Type
Overlays
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#firstHeading&quot; class=&quot;firstHeading&quot; lang=&quot;en&quot;&gt;&lt;span dir=&quot;auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlaysDrawingWinformsMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”&gt;&lt;span dir=“auto</a>
Return Type
WorldExtent
Return Type
thinkgeo.mapsuite.desktopedition.overlaysdrawingwinformsmapeventargs.1440040130.txt.gz · Last modified: 2015/09/18 03:04 (external edit)
