<!– Class –> This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn. This event allows you draw something with the canvas after the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs
OverlayDrawnWpfMapEventArgs | This is a constructor for the class. | ||
OverlayDrawnWpfMapEventArgs | Overlay, GeoCanvas | This is a constructor for the class. |
This is the default constructor. If you use this constructor then you need to set the required properties manually.
This constructor allows you to set the overlay drawn, the world extent and the image you have drawn on.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#OverlayDrawnWpfMapEventArgs.28Overlay.2C_GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#OverlayDrawnWpfMapEventArgs.28Overlay.2C_GeoCanvas.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#MemberwiseClone.28.29</a>
This property gets and sets the GeoCanvas we have drawn on.
| GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> |
<!– ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs –> Go Back
This property gets and sets the overlay you have drawn.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayDrawnWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
| Overlay<!– ThinkGeo.MapSuite.DesktopEdition.Overlay –> |
