thinkgeo.mapsuite.desktopedition.drawingoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.DrawingOverlayEventArgs
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn.
      • ThinkGeo.MapSuite.DesktopEdition.DrawingOverlayEventArgs
DrawingOverlayEventArgs()
This is the default constructor. If you use this constructor then you need to set the required properties manually.
DrawingOverlayEventArgs(GeoCanvas)
  • geoCanvas
    • Type:GeoCanvas
    • Description:This parameter is the GeoCanvas we are drawing on.
Cancel
This property gets and sets a value that determines whether you want to cancel the Overlay from drawing.
GeoCanvas
This property gets and sets the GeoCanvas we are drawing on.
thinkgeo.mapsuite.desktopedition.drawingoverlayeventargs.1442545328.txt.gz · Last modified: 2015/09/18 03:02 by admin
