<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.WmtsLayer
WmtsLayer | |||
WmtsLayer | IEnumerable<Uri> | ||
WmtsLayer | IEnumerable<Uri>, WebProxy | ||
WmtsLayer | IEnumerable<Uri>, WebProxy, WmtsSeverEncodingType |
ActiveLayerName | String | ||
ActiveStyleName | String | ||
CapabilitesCacheTimeout | TimeSpan | ||
Credentials | ICredentials | ||
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
LowerScale | Double | ||
OutputFormat | String | ||
Parameters | Dictionary<String,String> | ||
ServerUris | Collection<Uri> | ||
TileCache | BitmapTileCache | ||
TileMatrixSetName | String | ||
TimeoutInSeconds | Int32 | ||
UpperScale | Double | ||
WebProxy | WebProxy | ||
WmtsSeverEncodingType | WmtsSeverEncodingType |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| serverUris | IEnumerable<Uri><!– System.Collections.Generic.IEnumerable{System.Uri} –> |
| serverUris | IEnumerable<Uri><!– System.Collections.Generic.IEnumerable{System.Uri} –> | |
| webProxy | WebProxy<!– System.Net.WebProxy –> |
| webProxy | WebProxy<!– System.Net.WebProxy –> | |
| wmtsSeverEncodingType | WmtsSeverEncodingType<!– ThinkGeo.MapSuite.Core.WmtsSeverEncodingType –> |
Create a copy of Layer using the deep clone process.
This method closes the Layer and releases any resources it was using.
This method draws the Layer.
This method returns the bounding box of the Layer.
| layerName | String<!– System.String –> |
<!– ThinkGeo.MapSuite.Core.WmtsLayer –> Go Back
| Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –> |
| requestExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| canvasWidth | Int32<!– System.Int32 –> | |
| canvasHeight | Int32<!– System.Int32 –> |
<!– static –>
<!– static –>
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
| e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> |
| e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> |
| WebResponse<!– System.Net.WebResponse –> |
| webRequest | WebRequest<!– System.Net.WebRequest –> |
| ICredentials<!– System.Net.ICredentials –> |
The default value is false.
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
| BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
