This class represents the event arguments for the StreamLoading event.
This is the default constructor taking no arguments which is typically not used. Alternate Streams Where possible we allow you to use stream in place of concreate files on the file system. This gives you the flexibility to retrieve data from isolated storage, encrypted files, compressed files, fast memory streams or any other stream origin. This is typically available where you would pass in a path and file name. Streams can be substituted in a number of places such as images, shape files etc. Below describes how the system works though specific places may have slightly different variations. You will create the object that will use the stream normally such as a ShapeFielFeatureSource and then subscribe to the StreamLoading event. For these classes you typically need to supply a path and file name, while this is still required you can pass in a valid path that does not exist such as “Z:\ShapeFile1.shp”. When we need the stream from you we will give you this string so you can find the associated stream. In essence you can use the path and file name as a key to kink to the source of your stream. When we need the file we will raise the StreamLoading event and allow you to pass an alternate stream. In the StreamLoading event we provide you with the path and file name you used and we expect for you to create the stream and set it as the AlternatStream property along with setting the FileMode and File access appropriate to the stream. This helps us know our limits with the stream.
alternateStreamName
This is the constructor we suggest you you when creating this class. Alternate Streams Where possible we allow you to use stream in place of concreate files on the file system. This gives you the flexibility to retrieve data from isolated storage, encrypted files, compressed files, fast memory streams or any other stream origin. This is typically available where you would pass in a path and file name. Streams can be substituted in a number of places such as images, shape files etc. Below describes how the system works though specific places may have slightly different variations. You will create the object that will use the stream normally such as a ShapeFielFeatureSource and then subscribe to the StreamLoading event. For these classes you typically need to supply a path and file name, while this is still required you can pass in a valid path that does not exist such as “Z:\ShapeFile1.shp”. When we need the stream from you we will give you this string so you can find the associated stream. In essence you can use the path and file name as a key to kink to the source of your stream. When we need the file we will raise the StreamLoading event and allow you to pass an alternate stream. In the StreamLoading event we provide you with the path and file name you used and we expect for you to create the stream and set it as the AlternatStream property along with setting the FileMode and File access appropriate to the stream. This helps us know our limits with the stream.
alternateStreamName
fileMode
alternateStreamName
alternateStream
fileAccess
