thinkgeo.mapsuite.core.simplecandidate
ThinkGeo.MapSuite.Core.SimpleCandidate
This class stores simple label information used in the PositionStyle.
    • ThinkGeo.MapSuite.Core.SimpleCandidate
SimpleCandidate()
If you use this constructor, then you need to manually set the properties necessary for this class.
SimpleCandidate(String,PolygonShape)
  • originalText
    • Description:This parameter is the text for the label.
  • simplePolygonInScreenCoordinate
    • Description:This parameter is a polygon in screen coordinates that represents the area of the label.
OriginalText
This property gets and sets the text for the label.
SimplePolygonInScreenCoordinate
This property gets and sets the polygon in screen coordinates that represents the area of the label.
thinkgeo.mapsuite.core.simplecandidate.1442555518.txt.gz · Last modified: 2015/09/18 05:51 by admin
