<!– Class –> This class stores simple label information used in the PositionStyle.
This class is used in the PositionStyle for storing simple label infromation. It has a limited scope.
*System.Object **ThinkGeo.MapSuite.Core.SimpleCandidate
![]() | This is a constructor for the class. | ||
![]() | String, PolygonShape | This is a constructor for the class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | String | This property gets and sets the text for the label. | |
![]() | PolygonShape | This property gets and sets the polygon in screen coordinates that represents the area of the label. |
This is the default constructor. If you use this constructor, then you need to manually set the properties necessary for this class.
Name | Type | Description |
This constructor allows you to pass in the original text and the simple polygon in screen coordinates.
originalText | String<!– System.String –> | This parameter is the text for the label. |
simplePolygonInScreenCoordinate | PolygonShape<!– ThinkGeo.MapSuite.Core.PolygonShape –> | This parameter is a polygon in screen coordinates that represents the area of the label. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.Core.SimpleCandidate –> Go Back
Return Type |
