thinkgeo.mapsuite.core.shapevalidationresult
ThinkGeo.MapSuite.Core.ShapeValidationResult
    • System.ValueType
      • ThinkGeo.MapSuite.Core.ShapeValidationResult
ShapeValidationResult(Boolean,String)
This constructor allows you to set the IsValid and ValidationErrors properties.
  • isValid
    • Description:This parameter describes whether the object has passed its validation method.
  • validationErrors
    • Description:This parameter describes the list of errors if the object did not pass its validation method. The errors are separated by semicolons.
This method is an override of the Equals functionality.
This method is an override of the GetHashCode functionality.
IsValid
This property describes whether the object has passed its validation method.
ValidationErrors
This property describes the list of errors if the object did not pass its validation method.
If there are multiple errors, they will be separated by semicolons. If the object passed its validations, then this string will be empty.
thinkgeo.mapsuite.core.shapevalidationresult.1442555516.txt.gz · Last modified: 2015/09/18 05:51 by admin
