This constructor allows you to set the IsValid and ValidationErrors properties.
isValid
This method is an override of the Equals functionality.
This method is an override of the GetHashCode functionality.
This property describes whether the object has passed its validation method.
Return Type:Boolean
This property describes the list of errors if the object did not pass its validation method.
If there are multiple errors, they will be separated by semicolons. If the object passed its validations, then this string will be empty.
Return Type:String
