<!– Structure –> This structure represents the result of the validation method performed on a shape.
This is used to determine if an validation rule was broken for a shape. This structure also returns the description of the violation.
*System.ValueType **ThinkGeo.MapSuite.Core.ShapeValidationResult
![]() | Boolean, String | This constructor allows you to set the IsValid and ValidationErrors properties. |
![]() | Object | Object(overriden) | This method is an override of the Equals functionality. |
![]() | Object(overriden) | This method is an override of the GetHashCode functionality. | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Boolean | This property describes whether the object has passed its validation method. | |
![]() | String | This property describes the list of errors if the object did not pass its validation method. |
Name | Type | Description |
isValid | Boolean<!– System.Boolean –> | This parameter describes whether the object has passed its validation method. |
validationErrors | String<!– System.String –> | This parameter describes the list of errors if the object did not pass its validation method. The errors are separated by semicolons. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.Core.ShapeValidationResult –> Go Back
If there are multiple errors, they will be separated by semicolons. If the object passed its validations, then this string will be empty.
Return Type |
