thinkgeo.mapsuite.core.scaletextprinterlayer
Table of Contents
ThinkGeo.MapSuite.Core.ScaleTextPrinterLayer
<!– Class –>
Public MethodCloneDeep Layer Create a copy of Layer using the deep clone process.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetPosition PrintingUnit PrinterLayer
Public MethodGetPosition PrinterLayer
Public MethodGetType Object
Public MethodStatic MemberLoadLayer Uri Layer
Public MethodStatic MemberLoadLayer Stream Layer
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodRequestDrawing RectangleShape Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Layer
Public MethodRequestDrawing RectangleShape, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing RectangleShape, TimeSpan Layer
Public MethodRequestDrawing TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing TimeSpan Layer
Public MethodRequestDrawing IEnumerable<RectangleShape> Layer
Public MethodRequestDrawing Layer
Public MethodSetPosition Double, Double, Double, Double, PrintingUnit PrinterLayer
Public MethodSetPosition Double, Double, LayerAnchorLocation, PointShape, PrintingUnit PrinterLayer
Public MethodSetPosition Double, Double, LayerAnchorLocation, Double, Double, PrintingUnit PrinterLayer
Public MethodSetPosition RectangleShape PrinterLayer
Public MethodSetPosition RectangleShape, PrintingUnit PrinterLayer
Public MethodSetPosition Double, Double, PointShape, PrintingUnit PrinterLayer
Public MethodToString Object
Protected MethodCloneDeepCore Layer Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
Protected MethodCloseCore Layer This method closes the Layer and releases any resources it was using.
Protected MethodDrawAttributionCore GeoCanvas, String Layer
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden)
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden)
Protected MethodGetPositionCore PrintingUnit PrinterLayer
Protected MethodOnDrawingAttribution DrawingAttributionLayerEventArgs Layer
Protected MethodOnDrawingException DrawingExceptionLayerEventArgs Layer
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawnAttribution DrawnAttributionLayerEventArgs Layer
Protected MethodOnDrawnException DrawnExceptionLayerEventArgs Layer
Protected MethodOnRequestedDrawing RequestedDrawingLayerEventArgs Layer
Protected MethodOnRequestingDrawing RequestingDrawingLayerEventArgs Layer
Protected MethodOpenCore Layer This method opens the Layer so that it is initialized and ready to use.
Protected MethodSetPositionCore Double, Double, Double, Double, PrintingUnit PrinterLayer
Public PropertyAttribution String Layer
Public PropertyBackgroundMask AreaStyle PrinterLayer
Public PropertyBlueTranslation Single Layer This property gets and sets the amount of blue to apply to the image.
Public PropertyDragMode PrinterDragMode PrinterLayer
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyFont GeoFont
Public PropertyGreenTranslation Single Layer This property gets and sets the amount of green to apply to the image.
Public PropertyHasBoundingBox Boolean Layer(overriden)
Public PropertyIsDrawing Boolean PrinterLayer
Public PropertyIsGrayscale Boolean Layer This property gets and sets if the image should be converted to grayscale.
Public PropertyIsNegative Boolean Layer This property gets and sets whether the image should be converted to negative (inverse colors).
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyKeyColors Collection<GeoColor> Layer Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors.
Public PropertyMapPrinterLayer MapPrinterLayer
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyPrinterWrapMode PrinterWrapMode
Public PropertyPrintingUnit PrintingUnit
Public PropertyRedTranslation Single Layer This property gets and sets the amount of red to apply to the image.
Public PropertyRequestDrawingInterval TimeSpan Layer
Public PropertyResizeMode PrinterResizeMode PrinterLayer
Public PropertySelectabilityMode SelectabilityMode PrinterLayer
Public PropertyTextBrush GeoBrush
Public PropertyTransparency Single Layer This property gets and sets the amount of transparency to apply to the image.
Public PropertyWorldUnit DistanceUnit
Protected PropertyIsOpenCore Boolean Layer This property returns true if the Layer is open and false if it is not.
ScaleTextPrinterLayer()
Name Type Description
Go Back
ScaleTextPrinterLayer(PrintingUnit, DistanceUnit, MapPrinterLayer)
printingUnit PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –>
worldUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –>
mapPrinterLayer MapPrinterLayer<!– ThinkGeo.MapSuite.Core.MapPrinterLayer –>
Go Back
ScaleTextPrinterLayer(PrintingUnit, DistanceUnit, GeoFont, GeoBrush, MapPrinterLayer)
font GeoFont<!– ThinkGeo.MapSuite.Core.GeoFont –>
textBrush GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –>
Go Back
CloneDeep()
Return Type Description
Layer<!– ThinkGeo.MapSuite.Core.Layer –> A cloned Layer.
Close()
Void<!– System.Void –>
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns the bounding box of the Layer.
Int32<!– System.Int32 –>
GetPosition(PrintingUnit)
unit PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –>
<!– ThinkGeo.MapSuite.Core.PrinterLayer –> Go Back
GetPosition()
Type<!– System.Type –>
LoadLayer(Uri)
<!– static –>
layerUri Uri<!– System.Uri –>
LoadLayer(Stream)
<!– static –>
layerStream Stream<!– System.IO.Stream –>
Open()
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
bufferTime TimeSpan<!– System.TimeSpan –>
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(RectangleShape, TimeSpan)
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(TimeSpan)
RequestDrawing()
SetPosition(Double, Double, Double, Double, PrintingUnit)
width Double<!– System.Double –>
height Double<!– System.Double –>
centerPointX Double<!– System.Double –>
centerPointY Double<!– System.Double –>
SetPosition(Double, Double, LayerAnchorLocation, PointShape, PrintingUnit)
corner LayerAnchorLocation<!– ThinkGeo.MapSuite.Core.LayerAnchorLocation –>
cornerPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
SetPosition(Double, Double, LayerAnchorLocation, Double, Double, PrintingUnit)
cornerPointX Double<!– System.Double –>
cornerPointY Double<!– System.Double –>
SetPosition(RectangleShape)
boundingBox RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
SetPosition(RectangleShape, PrintingUnit)
SetPosition(Double, Double, PointShape, PrintingUnit)
centerPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
String<!– System.String –>
CloneDeepCore()
CloseCore()
DrawAttributionCore(GeoCanvas, String)
attribution String<!– System.String –>
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
GetPositionCore(PrintingUnit)
args DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –>
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –>
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –>
args DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –>
eventArgs RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –>
eventArgs RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –>
OpenCore()
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
SetPositionCore(Double, Double, Double, Double, PrintingUnit)
Attribution
Return Type
BackgroundMask
Return Type
AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –>
BlueTranslation
Return Type
Single<!– System.Single –>
DragMode
Return Type
PrinterDragMode<!– ThinkGeo.MapSuite.Core.PrinterDragMode –>
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
Return Type
Font
Return Type
<!– ThinkGeo.MapSuite.Core.ScaleTextPrinterLayer –> Go Back
GreenTranslation
Return Type
HasBoundingBox
Return Type
IsDrawing
Return Type
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
Return Type
IsVisible
Return Type
KeyColors
Return Type
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –>
MapPrinterLayer
Return Type
Return Type
PrinterWrapMode
Return Type
PrinterWrapMode<!– ThinkGeo.MapSuite.Core.PrinterWrapMode –>
PrintingUnit
Return Type
RedTranslation
Return Type
Return Type
ResizeMode
Return Type
PrinterResizeMode<!– ThinkGeo.MapSuite.Core.PrinterResizeMode –>
SelectabilityMode
Return Type
SelectabilityMode<!– ThinkGeo.MapSuite.Core.SelectabilityMode –>
TextBrush
Return Type
Transparency
Return Type
WorldUnit
Return Type
IsOpenCore
Return Type
DrawingAttribution
Event Arguments
Event Arguments
DrawingException
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
thinkgeo.mapsuite.core.scaletextprinterlayer.1440040130.txt.gz · Last modified: 2015/09/17 10:39 (external edit)
