<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.PrinterLayer ThinkGeo.MapSuite.Core.ScaleLinePrinterLayer
ScaleLinePrinterLayer | MapPrinterLayer |
BackgroundMask | AreaStyle | PrinterLayer | |
DragMode | PrinterDragMode | PrinterLayer | |
HaloPen | GeoPen | ||
HasBoundingBox | Boolean | Layer(overriden) | |
IsDrawing | Boolean | PrinterLayer | |
MapPrinterLayer | MapPrinterLayer | ||
MapUnit | GeographyUnit | ||
Pen | GeoPen | ||
ResizeMode | PrinterResizeMode | PrinterLayer | |
SelectabilityMode | SelectabilityMode | PrinterLayer | |
TextStyle | TextStyle | ||
UnitSystem | ScaleLineUnitSystem | Gets or sets the UnitSystem to be used for the ScaleLine. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| mapPrinterLayer | MapPrinterLayer<!– ThinkGeo.MapSuite.Core.MapPrinterLayer –> |
Create a copy of Layer using the deep clone process.
This method closes the Layer and releases any resources it was using.
This method draws the Layer.
This method returns the bounding box of the Layer.
| unit | PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –> |
<!– ThinkGeo.MapSuite.Core.PrinterLayer –> Go Back
<!– static –>
<!– static –>
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
| width | Double<!– System.Double –> | |
| height | Double<!– System.Double –> | |
| corner | LayerAnchorLocation<!– ThinkGeo.MapSuite.Core.LayerAnchorLocation –> | |
| cornerPointX | Double<!– System.Double –> | |
| cornerPointY | Double<!– System.Double –> | |
| cornerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| centerPointX | Double<!– System.Double –> | |
| centerPointY | Double<!– System.Double –> | |
| centerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
| PrinterDragMode<!– ThinkGeo.MapSuite.Core.PrinterDragMode –> |
| GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –> |
<!– ThinkGeo.MapSuite.Core.ScaleLinePrinterLayer –> Go Back
| PrinterResizeMode<!– ThinkGeo.MapSuite.Core.PrinterResizeMode –> |
| SelectabilityMode<!– ThinkGeo.MapSuite.Core.SelectabilityMode –> |
| TextStyle<!– ThinkGeo.MapSuite.Core.TextStyle –> |
By setting this property, you can set the top and button unit for the ScaleLine.
| ScaleLineUnitSystem<!– ThinkGeo.MapSuite.Core.ScaleLineUnitSystem –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
