<!– Class –> The ScaleBarAdornmentLayer class allows you show a bar graphic on the map that displays the distance scale for the current map extent.
Use the <strong>ScaleBarAdornmentLayer</strong> class as a quick way to implement a <strong>ScaleBar</strong>. When using the <strong>ScaleBarAdornmentLayer</strong>, you also need to add a ScaleLineAdornmentLayer to the map control. One thing we should pay attention to is that the ScaleBar will not be drawn when the CurrentExtent is outside of Range(-90,180,90,-180).
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.AdornmentLayer ThinkGeo.MapSuite.Core.ScaleBarAdornmentLayer
ScaleBarAdornmentLayer | Creates a new instance of the ScaleBarAdornmentLayer class. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetDrawingLocation | GeoCanvas, Single, Single | AdornmentLayer | This method returns the drawing location of the AdornmentLayer. |
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer | This method opens the Layer so that it is initialized and ready to use. |
AlternateBarBrush | GeoBrush | The property is the GeoBrush that will be used to draw the alternate ScaleBar. | |
BackgroundMask | AreaStyle | AdornmentLayer | |
BarBrush | GeoBrush | The property is the GeoBrush that will be used to draw the ScaleBar. | |
BarPen | GeoPen | ||
DisplayUnitString | Dictionary<String,String> | This propery is a dictionary that exposes what text will be drawn to represent the ScaleLine Unit. | |
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
HasMask | Boolean | Gets or sets whether the ScaleBar will have a mask or not. A boolean value representing whether or not a mask is shown. | |
Height | Single | AdornmentLayer | |
Location | AdornmentLocation | AdornmentLayer | This property gets and sets the drawing location of the AdornmentLayer. |
MaskBrush | GeoBrush | Gets or sets the color for the ScaleBarAdornmentLayer's mask, if the HasMask property is set to true. | |
MaskContour | GeoPen | Gets or sets the pen for the outline of the ScaleBar mask. | |
MaxWidth | Int32 | Gets or Sets the MaxWidth of the ScaleBar. | |
ProjectionToDecimalDegrees | Projection | Gets or sets a Proj4 projection parameter string which shows what coordinate system the map is using. | |
TextStyle | TextStyle | ||
Thickness | Int32 | Gets or sets the thickness of the ScaleBar. It is an integer value representing the height of the ScaleBar in screen units. | |
UnitFamily | UnitSystem | Gets or sets the UnitSystem (Imperial/Metric) to be used for the ScaleBar. | |
Width | Single | AdornmentLayer | |
XOffsetInPixel | Single | AdornmentLayer | This property gets and sets the X pixel offset for the AdornmentLayer. |
YOffsetInPixel | Single | AdornmentLayer | This property gets and sets the Y pixel offset for the AdornmentLayer. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
When displaying a <strong>ScaleBarAdornmentLayer</strong>, we need to instance a ScaleLineAdornmentLayer and add it to MapEngine. The ScaleBar will not be drawn when the <strong>CurrentExtent</strong> is outside of the world Extent(-90,180-,90,-180).
| ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | It returns the upper left screen point of where the AdornmentLayer will be drawn. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas used in drawing. |
| adornmentWidth | Single<!– System.Single –> | This parameter is the width of the adornment. |
| adornmentHeight | Single<!– System.Single –> | This parameter is the height of the adornment |
<!– ThinkGeo.MapSuite.Core.AdornmentLayer –> Go Back
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
This <strong>AlternateBarBrush</strong> property will give you full control over the appearance of the <strong>ScaleBarAdornmentLayer</strong>.
| GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> |
<!– ThinkGeo.MapSuite.Core.ScaleBarAdornmentLayer –> Go Back
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
This <strong>BarBrush</strong> property will give you full control over the appearance of the <strong>ScaleBarAdornmentLayer</strong>.
| GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –> |
We will display different letters for different units of measure; for example: “m” for meters, “ft” for feet, etc.
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
The default value is false.
Depending upon the look of your map and your requirements, you may or may not want a mask on the ScaleBar. You can control whether or not the ScaleBar has a mask by setting this property. If you set the <strong>HasMask</strong> property to true, be sure to specify a mask color (or texture) by using the <strong>MaskBrush</strong> property.
| AdornmentLocation<!– ThinkGeo.MapSuite.Core.AdornmentLocation –> |
By using this property you can control the border of the mask, if the <strong>HasMask</strong> property is set to true. If you do not want a contour or border to show, you should set the pen to transparent.
You can use this property to set the maximum width that you want the ScaleBar to occupy on the map. The <strong>ScaleBarAdornmentLayer</strong> will automatically adjust its size based upon the current extent of the map. By setting this property, you can control the maximum width the ScaleBar will occupy on the map.
| Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
| TextStyle<!– ThinkGeo.MapSuite.Core.TextStyle –> |
By setting this property, you can control whether to use a metric or imperial measurement system for the ScaleBar.
| UnitSystem<!– ThinkGeo.MapSuite.Core.UnitSystem –> |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
