<!– Class –>
PrinterZoomLevelSet | |||
PrinterZoomLevelSet | GeographyUnit, Double |
![]() GetHigherZoomLevelScale | Double, ZoomLevelSet | ZoomLevelSet | ZoomToScale out, the result is greater than input |
![]() GetLowerZoomLevelScale | Double, ZoomLevelSet | ZoomLevelSet | ZoomToScale in, the result is less than input |
GetZoomLevel | RectangleShape, Double, GeographyUnit | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a screen width. |
GetZoomLevel | RectangleShape, Double, GeographyUnit, Single | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a screen width. |
GetZoomLevelForDrawing | RectangleShape, Double, GeographyUnit, Single | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a canvas width. |
GetZoomLevelForDrawing | RectangleShape, Double, GeographyUnit | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a canvas width. |
GetZoomLevels | ZoomLevelSet | This method return all of the zoomLevels in the zoomLevelSet. | |
GetZoomPercentage | ZoomLevel | ||
CustomZoomLevels | Collection<ZoomLevel> | ZoomLevelSet | This property gets the custom zoom levels from the zoomLevelSet. |
Name | String | ZoomLevelSet | This property gets and sets the name for the ZoomSet. |
PageBaseUnit | GeographyUnit | ||
PageBaseUnitToPageUnitRatio | Double | ||
ZoomLevel01 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level01. |
ZoomLevel02 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level02. |
ZoomLevel03 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level03. |
ZoomLevel04 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level04. |
ZoomLevel05 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level05. |
ZoomLevel06 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level06. |
ZoomLevel07 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level07. |
ZoomLevel08 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level08. |
ZoomLevel09 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level09. |
ZoomLevel10 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level10. |
ZoomLevel11 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level11. |
ZoomLevel12 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level12. |
ZoomLevel13 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level13. |
ZoomLevel14 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level14. |
ZoomLevel15 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level15. |
ZoomLevel16 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level16. |
ZoomLevel17 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level17. |
ZoomLevel18 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level18. |
ZoomLevel19 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level19. |
ZoomLevel20 | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level20. |
| pageBaseUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | |
| pageBaseUnitToPageUnitRatio | Double<!– System.Double –> |
<!– static –> ZoomToScale out, the result is greater than input
| currentScale | Double<!– System.Double –> | |
| zoomLevelSet | ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> Go Back
<!– static –> ZoomToScale in, the result is less than input
| ZoomLevel<!– ThinkGeo.MapSuite.Core.ZoomLevel –> | This method returns the active ZoomLevel based on an extent, a map unit and a screen width. |
| extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is a world extent. |
| screenWidth | Double<!– System.Double –> | This parameter is the width of the map in pixels. |
| mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | This parameter is the unit of the map. |
| dpi | Single<!– System.Single –> | This parameter is the dpi of the extent. |
| ZoomLevel<!– ThinkGeo.MapSuite.Core.ZoomLevel –> | This method returns the active ZoomLevel based on an extent, map unit and a canvas width. |
| screenWidth | Double<!– System.Double –> | This parameter is the width of the canvas in pixels. |
| Collection<ZoomLevel><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.ZoomLevel} –> | This method return all of the zoomlevels in the zoomLevelSet. |
| ZoomLevel | ZoomLevel<!– ThinkGeo.MapSuite.Core.ZoomLevel –> |
<!– ThinkGeo.MapSuite.Core.PrinterZoomLevelSet –> Go Back
