thinkgeo.mapsuite.core.pointstyles
Table of Contents
ThinkGeo.MapSuite.Core.PointStyles
<!– Class –> This class provides commonly-used GeoPointStyles and some methods to create various kinds of GeoPointstyles. A GeoStyle is a kind of sheet used to render the map.
The <strong>GeoStyle</strong> is a very important concept. MapSuite provides three kinds of styles: <strong>GeoAreaStyle</strong>, <strong>GeoLineStyle</strong>, and <strong>GeoPointStyle</strong>. <strong>GeoAreaStyle</strong> is used to render area-type data on the map, <strong>GeoLineStyle</strong> is used to render line-type data on the map, <strong>GeoPointStyle</strong> is used to render point-type data on the map.
Public MethodStatic MemberCreateCompoundCircleStyle GeoColor, Single, GeoColor, Single, GeoColor, Single, GeoColor, Single Static API to create a compound circle point style.
Public MethodStatic MemberCreateCompoundCircleStyle GeoColor, Single, GeoColor, Single, GeoColor, Single Static API to create a compound circle point style.
Public MethodStatic MemberCreateCompoundPointStyle PointSymbolType, GeoColor, GeoColor, Single, Single, PointSymbolType, GeoColor, GeoColor, Single, Single Static API to create a compound circle point style.
Public MethodStatic MemberCreateSimpleCircleStyle GeoColor, Single, GeoColor Static API to create a circle point style.
Public MethodStatic MemberCreateSimpleCircleStyle GeoColor, Single, GeoColor, Single Static API to create a circle point style.
Public MethodStatic MemberCreateSimpleCircleStyle GeoColor, Single Static API to create a circle point style.
Public MethodStatic MemberCreateSimplePointStyle PointSymbolType, GeoColor, GeoColor, Single Static API to create a point style.
Public MethodStatic MemberCreateSimplePointStyle PointSymbolType, GeoColor, GeoColor, Single, Single Static API to create a point style.
Public MethodStatic MemberCreateSimplePointStyle PointSymbolType, GeoColor, Single Static API to create a point style.
Public MethodStatic MemberCreateSimpleSquareStyle GeoColor, Single, GeoColor, Single Static API to create a square point style.
Public MethodStatic MemberCreateSimpleSquareStyle GeoColor, Single Static API to create a square point style.
Public MethodStatic MemberCreateSimpleSquareStyle GeoColor, Single, GeoColor Static API to create a square point style.
Public MethodStatic MemberCreateSimpleStarStyle GeoColor, Single, GeoColor Static API to create a star point style.
Public MethodStatic MemberCreateSimpleStarStyle GeoColor, Single, GeoColor, Single Static API to create a star point style.
Public MethodStatic MemberCreateSimpleStarStyle GeoColor, Single Static API to create a star point style.
Public MethodStatic MemberCreateSimpleTriangleStyle GeoColor, Single Static API to create a triangle point style.
Public MethodStatic MemberCreateSimpleTriangleStyle GeoColor, Single, GeoColor Static API to create a triangle point style.
Public MethodStatic MemberCreateSimpleTriangleStyle GeoColor, Single, GeoColor, Single Static API to create a triangle point style.
Public MethodGetType Object
Public MethodToString Object
Public PropertyStatic MemberCapital1 PointStyle Get the commonly-used PointStyle to render a capital.
Public PropertyStatic MemberCapital2 PointStyle Get the commonly-used PointStyle to render a capital.
Public PropertyStatic MemberCapital3 PointStyle Get the commonly-used PointStyle to render a capital.
Public PropertyStatic MemberCity1 PointStyle Get the commonly-used PointStyle to render a city.
Public PropertyStatic MemberCity2 PointStyle Get the commonly-used PointStyle to render a city.
Public PropertyStatic MemberCity3 PointStyle Get the commonly-used PointStyle to render a city.
Public PropertyStatic MemberCity4 PointStyle Get the commonly-used PointStyle to render a city.
Public PropertyStatic MemberCity5 PointStyle Get the commonly-used PointStyle to render a city.
Public PropertyStatic MemberCity6 PointStyle Get the commonly-used PointStyle to render a city.
Public PropertyStatic MemberCity7 PointStyle Get the commonly-used PointStyle to render a city.
CreateCompoundCircleStyle(GeoColor, Single, GeoColor, Single, GeoColor, Single, GeoColor, Single)
<!– static –> Static API to create a compound circle point style.
Return Type Description
PointStyle<!– ThinkGeo.MapSuite.Core.PointStyle –> The created point style.
Name Type Description
fillColor1 GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> This parameter determines the outer circle's PointStyle fill color.
size1 Single<!– System.Single –> This parameter determines the outer circle's PointStyle size.
outlineColor1 GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> This parameter determines the outer circle's PointStyle outline color.
outlineWidth1 Single<!– System.Single –> This parameter determines the outer circle's PointStyle outline width.
fillColor2 GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> This parameter determines the inner circle's PointStyle fill color.
size2 Single<!– System.Single –> This parameter determines the inner circle's PointStyle size.
outlineColor2 GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> This parameter determines the inner circle's PointStyle outline color.
outlineWidth2 Single<!– System.Single –> This parameter determines the inner circle's PointStyle outline width.
<!– ThinkGeo.MapSuite.Core.PointStyles –> Go Back
CreateCompoundCircleStyle(GeoColor, Single, GeoColor, Single, GeoColor, Single)
CreateCompoundPointStyle(PointSymbolType, GeoColor, GeoColor, Single, Single, PointSymbolType, GeoColor, GeoColor, Single, Single)
pointStyle1 PointSymbolType<!– ThinkGeo.MapSuite.Core.PointSymbolType –> This parameter determines the outer circle's pointstyle symbol type.
pointStyle2 PointSymbolType<!– ThinkGeo.MapSuite.Core.PointSymbolType –> This parameter determines the inner circle's pointstyle symbol type.
size2 Single<!– System.Single –> This parameter determines the inner circle PointStyle size.
CreateSimpleCircleStyle(GeoColor, Single, GeoColor)
<!– static –> Static API to create a circle point style.
fillColor GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> This parameter determines the PointStyle fill color.
size Single<!– System.Single –> This parameter determines the PointStyle size.
outlineColor GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> This parameter determines the PointStyle outline color.
CreateSimpleCircleStyle(GeoColor, Single, GeoColor, Single)
outlineWidth Single<!– System.Single –> This parameter determines the PointStyle outline width.
CreateSimpleCircleStyle(GeoColor, Single)
CreateSimplePointStyle(PointSymbolType, GeoColor, GeoColor, Single)
<!– static –> Static API to create a point style.
pointStyle PointSymbolType<!– ThinkGeo.MapSuite.Core.PointSymbolType –> This parameter determines the PointStyle symbol type.
CreateSimplePointStyle(PointSymbolType, GeoColor, GeoColor, Single, Single)
CreateSimplePointStyle(PointSymbolType, GeoColor, Single)
CreateSimpleSquareStyle(GeoColor, Single, GeoColor, Single)
<!– static –> Static API to create a square point style.
CreateSimpleSquareStyle(GeoColor, Single)
CreateSimpleSquareStyle(GeoColor, Single, GeoColor)
CreateSimpleStarStyle(GeoColor, Single, GeoColor)
<!– static –> Static API to create a star point style.
CreateSimpleStarStyle(GeoColor, Single, GeoColor, Single)
CreateSimpleStarStyle(GeoColor, Single)
CreateSimpleTriangleStyle(GeoColor, Single)
<!– static –> Static API to create a triangle point style.
CreateSimpleTriangleStyle(GeoColor, Single, GeoColor)
CreateSimpleTriangleStyle(GeoColor, Single, GeoColor, Single)
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Capital1
<!– static –> Get the commonly-used PointStyle to render a capital.
Return Type
Capital2
Return Type
Capital3
Return Type
City1
<!– static –> Get the commonly-used PointStyle to render a city.
Return Type
City2
Return Type
City3
Return Type
City4
Return Type
City5
Return Type
City6
Return Type
City7
Return Type
thinkgeo.mapsuite.core.pointstyles.1440040129.txt.gz · Last modified: 2015/09/17 10:37 (external edit)
