thinkgeo.mapsuite.core.mrsidrasterlayer
ThinkGeo.MapSuite.Core.MrSidRasterLayer
This class represents a MrSid image to be drawn on the map.
      • ThinkGeo.MapSuite.Core.RasterLayer
        • ThinkGeo.MapSuite.Core.MrSidRasterLayer
MrSidRasterLayer()
If you use this constructor then, you need to set the PathFileName property manually before using the layer.
MrSidRasterLayer(String)
  • imagePathFilename
    • Description:This parameter is the path and filename of the MrSid file you want to use.
MrSidRasterLayer(String,String)
  • imagePathFilename
    • Description:This parameter is the path and filename of the MrSid image file you want to use.
  • worldFilePathFilename
    • Description:This parameter is the world file path and filename for the MrSid image you want to use.
MrSidRasterLayer(String,RectangleShape)
  • imagePathFilename
  • imageExtent
    • Description:This parameter is the image extent of the MrSid image file you want to use.
Dispose()
Release the unmanage resource in RasterSource.
GetProjectionText()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
GetBoundingBoxCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
PathFilename
This property gets and sets the path and filename of the MrSid file you want to use.
This should be a complete path and filename for the MrSid file.
SuppressClose
Gets or sets the SuppressClose property.
If set the SuppressClose to ture, then the RasterSource will not be closed even you call the Close API.
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In mrSidRasterLayer, we override this API and mark it as true.
ImageSource
UpperThreshold
LowerThreshold
HasProjectionText
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
IsOpenCore
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.mrsidrasterlayer.1442555236.txt.gz · Last modified: 2015/09/18 05:47 by admin
