thinkgeo.mapsuite.core.mrsidrasterlayer
Table of Contents
ThinkGeo.MapSuite.Core.MrSidRasterLayer
<!– Class –> This class represents a MrSid image to be drawn on the map.
The MrSidRasterLayer represents a MrSid file for drawing on the map. Simply provide the path and filename to the MrSid file, add the layer to the MapEngine class and start drawing. You can also draw the layer manually outside of the MapEngine.
MrSid:
MrSid is a image compression system developed by LizardTech. It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales. It is very popular in the GIS community.
Public MethodMrSidRasterLayer This is a constructor for the class.
Public MethodMrSidRasterLayer String This is a constructor for the class.
Public MethodMrSidRasterLayer String, String This is a constructor for the class.
Public MethodMrSidRasterLayer String, RectangleShape This is a constructor for the class.
Public MethodCloneDeep Layer Create a copy of Layer using the deep clone process.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDispose Release the unmanage resource in RasterSource.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetHorizontalResolution RasterLayer This method returns the horizontal resolution of the image.
Public MethodGetProjectionText RasterLayer This method returns the projection parameters of the current layer.
Public MethodGetType Object
Public MethodGetVerticalResolution RasterLayer This method returns the vertical resolution of the image.
Public MethodStatic MemberLoadLayer Uri Layer
Public MethodStatic MemberLoadLayer Stream Layer
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodRequestDrawing RectangleShape, TimeSpan Layer
Public MethodRequestDrawing RectangleShape, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Layer
Public MethodRequestDrawing TimeSpan Layer
Public MethodRequestDrawing IEnumerable<RectangleShape> Layer
Public MethodRequestDrawing RectangleShape Layer
Public MethodRequestDrawing Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodToString Object
Protected MethodCloneDeepCore Layer Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
Protected MethodCloseCore Layer(overriden)
Protected MethodDrawAttributionCore GeoCanvas, String Layer
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden)
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden)
Protected MethodOnDrawingAttribution DrawingAttributionLayerEventArgs Layer
Protected MethodOnDrawingException DrawingExceptionLayerEventArgs Layer
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawnAttribution DrawnAttributionLayerEventArgs Layer
Protected MethodOnDrawnException DrawnExceptionLayerEventArgs Layer
Protected MethodOnRequestedDrawing RequestedDrawingLayerEventArgs Layer
Protected MethodOnRequestingDrawing RequestingDrawingLayerEventArgs Layer
Protected MethodOpenCore Layer(overriden)
Public PropertyAttribution String Layer
Public PropertyBlueTranslation Single Layer This property gets and sets the amount of blue to apply to the image.
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyGreenTranslation Single Layer This property gets and sets the amount of green to apply to the image.
Public PropertyHasBoundingBox Boolean Layer(overriden) This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In mrSidRasterLayer, we override this API and mark it as true.
Public PropertyHasProjectionText Boolean RasterLayer This property returns true if the RasterLayer contains projection parameters and false if it does not contain any projection parameters.
Public PropertyImageSource RasterSource RasterLayer This property gets and sets the ImageSource used by the RasterLayer.
Public PropertyIsGrayscale Boolean Layer This property gets and sets if the image should be converted to grayscale.
Public PropertyIsNegative Boolean Layer This property gets and sets whether the image should be converted to negative (inverse colors).
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyKeyColors Collection<GeoColor> Layer Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors.
Public PropertyLowerThreshold Double RasterLayer This property gets and sets the lower threshold in the scale at which to display the image.
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyPathFilename String This property gets and sets the path and filename of the MrSid file you want to use.
Public PropertyRedTranslation Single Layer This property gets and sets the amount of red to apply to the image.
Public PropertyRequestDrawingInterval TimeSpan Layer
Public PropertySuppressClose Boolean Gets or sets the SuppressClose property.
Public PropertyTransparency Single Layer This property gets and sets the amount of transparency to apply to the image.
Public PropertyUpperThreshold Double RasterLayer This property gets and sets the upper threshold in the scale at which to display the image.
Protected PropertyIsOpenCore Boolean Layer(overriden)
MrSidRasterLayer()
Overloads
This is the default constructor. If you use this constructor, then you need to set the PathFileName property manually before using the layer.
If you use this constructor then, you need to set the PathFileName property manually before using the layer.
Name Type Description
Go Back
MrSidRasterLayer(String)
Overloads
This constructor allows you to provide the path and filename information for the MrSid file.
imagePathFilename String<!– System.String –> This parameter is the path and filename of the MrSid file you want to use.
Go Back
MrSidRasterLayer(String, String)
Overloads
This constructor allows you to provide the path and filename information for both the MrSid image and its world file.
imagePathFilename String<!– System.String –> This parameter is the path and filename of the MrSid image file you want to use.
worldFilePathFilename String<!– System.String –> This parameter is the world file path and filename for the MrSid image you want to use.
Go Back
MrSidRasterLayer(String, RectangleShape)
Overloads
This constructor allows you to provide the path and filename for the MrSid image file and the image extent to use.
imageExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is the image extent of the MrSid image file you want to use.
Go Back
CloneDeep()
Return Type Description
Layer<!– ThinkGeo.MapSuite.Core.Layer –> A cloned Layer.
Close()
Void<!– System.Void –>
Dispose()
<!– ThinkGeo.MapSuite.Core.MrSidRasterLayer –> Go Back
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns the bounding box of the Layer.
Int32<!– System.Int32 –>
GetHorizontalResolution()
Single<!– System.Single –> This method returns the horizontal resolution of the image.
<!– ThinkGeo.MapSuite.Core.RasterLayer –> Go Back
GetProjectionText()
String<!– System.String –> This method returns the projection parameters of the current layer.
Type<!– System.Type –>
GetVerticalResolution()
Single<!– System.Single –> This method returns the vertical resolution of the image.
LoadLayer(Uri)
<!– static –>
layerUri Uri<!– System.Uri –>
LoadLayer(Stream)
<!– static –>
layerStream Stream<!– System.IO.Stream –>
Open()
RequestDrawing(RectangleShape, TimeSpan)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
bufferTime TimeSpan<!– System.TimeSpan –>
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
RequestDrawing(TimeSpan)
RequestDrawing()
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
CloneDeepCore()
CloseCore()
DrawAttributionCore(GeoCanvas, String)
attribution String<!– System.String –>
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
args DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –>
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –>
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –>
args DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –>
eventArgs RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –>
eventArgs RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –>
OpenCore()
Attribution
Return Type
BlueTranslation
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
Return Type
GreenTranslation
Return Type
HasBoundingBox
Return Type
HasProjectionText
Return Type
ImageSource
The set for this property is protected and only intended to be used by developers who are creating their own ImageSources. This is the main property to set for developers who are creating their own RasterLayer derivatives.
Return Type
RasterSource<!– ThinkGeo.MapSuite.Core.RasterSource –>
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
Return Type
IsVisible
Return Type
KeyColors
Return Type
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –>
LowerThreshold
Below the lower threshold in scale, the image will not be displayed. This, in conjunction with the UpperThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type
Double<!– System.Double –>
Return Type
PathFilename
This should be a complete path and filename for the MrSid file.
Return Type
RedTranslation
Return Type
Return Type
SuppressClose
If set the SuppressClose to ture, then the RasterSource will not be closed even you call the Close API.
Return Type
Transparency
Return Type
UpperThreshold
Above the upper threshold in scale, the image will not be displayed. This, in conjunction with the LowerThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type
IsOpenCore
Return Type
DrawingAttribution
Event Arguments
Event Arguments
DrawingException
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
thinkgeo.mapsuite.core.mrsidrasterlayer.1440040129.txt.gz · Last modified: 2015/09/17 10:35 (external edit)
