<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.PrinterLayer ThinkGeo.MapSuite.Core.MapPrinterLayer
![]() | IEnumerable<Layer>, RectangleShape, GeographyUnit |
![]() | String | Layer | |
![]() | AreaStyle | PrinterLayer | |
![]() | Single | Layer | This property gets and sets the amount of blue to apply to the image. |
![]() | PrinterDragMode | PrinterLayer | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | MapPrinterDrawingMode | ||
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | Single | Layer | This property gets and sets the amount of green to apply to the image. |
![]() | Boolean | Layer(overriden) | |
![]() | Boolean | PrinterLayer | |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Collection<GeoColor> | Layer | Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors. |
![]() | GeoCollection<Layer> | ||
![]() | RectangleShape | ||
![]() | GeographyUnit | ||
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | MapPrinterPreviewDrawingMode | ||
![]() | Single | Layer | This property gets and sets the amount of red to apply to the image. |
![]() | TimeSpan | Layer | |
![]() | PrinterResizeMode | PrinterLayer | |
![]() | SelectabilityMode | PrinterLayer | |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
Name | Type | Description |
layers | IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Layer} –> | |
mapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
Create a copy of Layer using the deep clone process.
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.Core.Layer –> | A cloned Layer. |
This method closes the Layer and releases any resources it was using.
Void<!– System.Void –> |
This method draws the Layer.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
This method returns the bounding box of the Layer.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
unit | PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –> |
<!– ThinkGeo.MapSuite.Core.PrinterLayer –> Go Back
Type<!– System.Type –> |
<!– static –>
layerUri | Uri<!– System.Uri –> |
<!– static –>
layerStream | Stream<!– System.IO.Stream –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> | |
bufferTimeType | RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> | |
width | Double<!– System.Double –> | |
height | Double<!– System.Double –> | |
corner | LayerAnchorLocation<!– ThinkGeo.MapSuite.Core.LayerAnchorLocation –> | |
cornerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
centerPointX | Double<!– System.Double –> | |
centerPointY | Double<!– System.Double –> | |
centerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
cornerPointX | Double<!– System.Double –> | |
cornerPointY | Double<!– System.Double –> | |
String<!– System.String –> |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
attribution | String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –> |
Return Type |
Return Type |
AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
Return Type |
Single<!– System.Single –> |
Return Type |
PrinterDragMode<!– ThinkGeo.MapSuite.Core.PrinterDragMode –> |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
MapPrinterDrawingMode<!– ThinkGeo.MapSuite.Core.MapPrinterDrawingMode –> |
<!– ThinkGeo.MapSuite.Core.MapPrinterLayer –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –> |
Return Type |
GeoCollection<Layer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Layer} –> |
Return Type |
Return Type |
Return Type |
Return Type |
MapPrinterPreviewDrawingMode<!– ThinkGeo.MapSuite.Core.MapPrinterPreviewDrawingMode –> |
Return Type |
Return Type |
Return Type |
PrinterResizeMode<!– ThinkGeo.MapSuite.Core.PrinterResizeMode –> |
Return Type |
SelectabilityMode<!– ThinkGeo.MapSuite.Core.SelectabilityMode –> |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
