thinkgeo.mapsuite.core.legendadornmentlayer
Table of Contents
ThinkGeo.MapSuite.Core.LegendAdornmentLayer
<!– Class –>
Public MethodLegendAdornmentLayer
Public MethodCloneDeep Layer Create a copy of Layer using the deep clone process.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetDrawingLocation GeoCanvas, Single, Single AdornmentLayer This method returns the drawing location of the AdornmentLayer.
Public MethodGetType Object
Public MethodStatic MemberLoadLayer Uri Layer
Public MethodStatic MemberLoadLayer Stream Layer
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodRequestDrawing TimeSpan Layer
Public MethodRequestDrawing TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Layer
Public MethodRequestDrawing RectangleShape, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing IEnumerable<RectangleShape> Layer
Public MethodRequestDrawing RectangleShape Layer
Public MethodRequestDrawing RectangleShape, TimeSpan Layer
Public MethodToString Object
Protected MethodCloneDeepCore Layer Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
Protected MethodCloseCore Layer This method closes the Layer and releases any resources it was using.
Protected MethodDrawAttributionCore GeoCanvas, String Layer
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden)
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer This method returns the bounding box of the Layer.
Protected MethodOnDrawingAttribution DrawingAttributionLayerEventArgs Layer
Protected MethodOnDrawingException DrawingExceptionLayerEventArgs Layer
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawnAttribution DrawnAttributionLayerEventArgs Layer
Protected MethodOnDrawnException DrawnExceptionLayerEventArgs Layer
Protected MethodOnRequestedDrawing RequestedDrawingLayerEventArgs Layer
Protected MethodOnRequestingDrawing RequestingDrawingLayerEventArgs Layer
Protected MethodOpenCore Layer This method opens the Layer so that it is initialized and ready to use.
Public PropertyAttribution String Layer
Public PropertyBackgroundMask AreaStyle AdornmentLayer
Public PropertyBlueTranslation Single Layer This property gets and sets the amount of blue to apply to the image.
Public PropertyContentResizeMode LegendContentResizeMode
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyFooter LegendItem
Public PropertyGreenTranslation Single Layer This property gets and sets the amount of green to apply to the image.
Public PropertyHasBoundingBox Boolean Layer This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
Public PropertyHeight Single AdornmentLayer
Public PropertyIsGrayscale Boolean Layer This property gets and sets if the image should be converted to grayscale.
Public PropertyIsNegative Boolean Layer This property gets and sets whether the image should be converted to negative (inverse colors).
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyKeyColors Collection<GeoColor> Layer Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors.
Public PropertyLegendItems GeoCollection<LegendItem>
Public PropertyLocation AdornmentLocation AdornmentLayer This property gets and sets the drawing location of the AdornmentLayer.
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyRedTranslation Single Layer This property gets and sets the amount of red to apply to the image.
Public PropertyRequestDrawingInterval TimeSpan Layer
Public PropertyTitle LegendItem
Public PropertyTransparency Single Layer This property gets and sets the amount of transparency to apply to the image.
Public PropertyWidth Single AdornmentLayer
Public PropertyXOffsetInPixel Single AdornmentLayer This property gets and sets the X pixel offset for the AdornmentLayer.
Public PropertyYOffsetInPixel Single AdornmentLayer This property gets and sets the Y pixel offset for the AdornmentLayer.
Protected PropertyIsOpenCore Boolean Layer This property returns true if the Layer is open and false if it is not.
LegendAdornmentLayer()
Name Type Description
Go Back
CloneDeep()
Return Type Description
Layer<!– ThinkGeo.MapSuite.Core.Layer –> A cloned Layer.
Close()
Void<!– System.Void –>
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns the bounding box of the Layer.
GetDrawingLocation(GeoCanvas, Single, Single)
ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> It returns the upper left screen point of where the AdornmentLayer will be drawn.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas used in drawing.
adornmentWidth Single<!– System.Single –> This parameter is the width of the adornment.
adornmentHeight Single<!– System.Single –> This parameter is the height of the adornment
<!– ThinkGeo.MapSuite.Core.AdornmentLayer –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
LoadLayer(Uri)
<!– static –>
layerUri Uri<!– System.Uri –>
LoadLayer(Stream)
<!– static –>
layerStream Stream<!– System.IO.Stream –>
Open()
RequestDrawing(TimeSpan)
bufferTime TimeSpan<!– System.TimeSpan –>
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing()
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(RectangleShape, TimeSpan)
String<!– System.String –>
CloneDeepCore()
CloseCore()
DrawAttributionCore(GeoCanvas, String)
attribution String<!– System.String –>
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
args DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –>
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –>
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –>
args DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –>
eventArgs RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –>
eventArgs RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –>
OpenCore()
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
Attribution
Return Type
BackgroundMask
Return Type
AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –>
BlueTranslation
Return Type
ContentResizeMode
Return Type
LegendContentResizeMode<!– ThinkGeo.MapSuite.Core.LegendContentResizeMode –>
<!– ThinkGeo.MapSuite.Core.LegendAdornmentLayer –> Go Back
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
Return Type
Return Type
LegendItem<!– ThinkGeo.MapSuite.Core.LegendItem –>
GreenTranslation
Return Type
HasBoundingBox
The default value is false.
Return Type
Height
Return Type
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
Return Type
IsVisible
Return Type
KeyColors
Return Type
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –>
LegendItems
Return Type
GeoCollection<LegendItem><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.LegendItem} –>
Location
Return Type
AdornmentLocation<!– ThinkGeo.MapSuite.Core.AdornmentLocation –>
Return Type
RedTranslation
Return Type
Return Type
Title
Return Type
Transparency
Return Type
Width
Return Type
XOffsetInPixel
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
Return Type
YOffsetInPixel
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
Return Type
IsOpenCore
Return Type
DrawingAttribution
Event Arguments
Event Arguments
DrawingException
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
thinkgeo.mapsuite.core.legendadornmentlayer.1440040129.txt.gz · Last modified: 2015/09/17 10:33 (external edit)
