thinkgeo.mapsuite.core.layerdrawingeventargs
ThinkGeo.MapSuite.Core.LayerDrawingEventArgs
      • ThinkGeo.MapSuite.Core.LayerDrawingEventArgs
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is a constructor for the class.
  • Parameters:Layer,RectangleShape,Object
  • DeclaringType:N/A
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetType
  • Parameters:N/A
  • Summary:N/A
ToString
  • Parameters:N/A
  • Summary:N/A
Finalize
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
Cancel
  • Return:Boolean
  • Summary:This property gets and sets the value that indicates you want to cancel the layer from drawing.
CurrentLayer
  • Return:Layer
  • Summary:This property gets and sets current layer that will be drawn.
NativeImage
  • Return:Object
  • Summary:This property gets and sets the GeoImage or native image that we are drawing on.
WorldExtent
  • Summary:This property gets and sets the world extent that will be drawn.
LayerDrawingEventArgs()
LayerDrawingEventArgs(Layer,RectangleShape,Object)
currentLayer
  • Type:Layer
  • Description:This parameter is the layer you will be drawing. worldExtent * Type:RectangleShape * Description:This parameter is the world extent you are drawing.
nativeImage
  • Description:This parameter is the GeoImage or native map image. Go Back ===== Protected Constructors ===== ===== Public Methods ===== === Equals(Object) === N/A ==== Remarks ==== N/A Return Value * Return Type:Boolean * Description:N/A ==== Parameters ==== obj * Type:Object * Description:N/A Go Back === GetHashCode() === N/A ==== Remarks ==== N/A Return Value * Return Type:Int32 * Description:N/A ==== Parameters ==== Go Back === GetType() === N/A ==== Remarks ==== N/A Return Value * Return Type:Type * Description:N/A ==== Parameters ==== Go Back === ToString() === N/A ==== Remarks ==== N/A Return Value * Return Type:String * Description:N/A ==== Parameters ==== Go Back ===== Protected Methods ===== === Finalize() === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== Go Back === MemberwiseClone() === N/A ==== Remarks ==== N/A Return Value * Return Type:Object * Description:N/A ==== Parameters ==== Go Back ===== Public Properties ===== === Cancel === This property gets and sets the value that indicates you want to cancel the layer from drawing. ==== Remarks ==== None ==== Return Value ==== Return Type:Boolean Go Back === CurrentLayer === This property gets and sets current layer that will be drawn. ==== Remarks ==== None ==== Return Value ==== Return Type:Layer Go Back === NativeImage === This property gets and sets the GeoImage or native image that we are drawing on. ==== Remarks ==== None ==== Return Value ==== Return Type:Object Go Back === WorldExtent === This property gets and sets the world extent that will be drawn. ==== Remarks ==== None ==== Return Value ==== Return Type**:RectangleShape
Go Back
thinkgeo.mapsuite.core.layerdrawingeventargs.1442486023.txt.gz · Last modified: 2015/09/17 10:33 by admin
